Max Hp Out Of Standard Rb25
LNEMUP498HP
Anyways Adrian
i dont know if you are having a bitch or talking good
ill let my car do the talking
Bitching mainly, just NOT about you or your car. There are some pretenders on this forum/thread. Sift through the BS and you'll be right.
Good luck with the rear end at the track - I'll be there cheering the 10's!
Adrian
Yep I agree, let the car do the talking
Awesome to see a workshop pushing a good old RB25 to the limits though, I know If I owned a workshop I probably would of done the same ... RB25 POWAH :(
yay for the good ol understated rb25 :PBJ:
Adrian
does your car select gears when your racing. i mean do they go in smooth as mine wont go in.
For me to shift i needa shift at 6500
how do u fix this problem other then upgrading to a different box
is it something to do with oil or syncros etc
Adrian
Always - want the low-down? Gimme a call and I'll pay you a visit. I wanna see this thing in the flesh! :(
Adrian
Changed fuel to c16
I gained 26 Hp without fine tuning so i can say there is a majour difference
I will be taking the car to powercruise so if people wish to have a look at the car they are more then welcome.
i am going to mainly be crusing round and might give drifting a go with this package but i dont think its to drift friendly
lol
Edited by LNEMUP498HP
NICE WORK all keyboard warriors told me my engine was gonna blow with 301 rwkw but a yr later its still fine and i thrash it daily...JMS are makin 360 kw on a standard rb25 and drift em..keep pushin it till it blows....
You really have to admire the japs. to build engines that can take that much power out of a stock bottom end for that long....damn i respect them. THe RBs, the SRs.....they really know their s#!t. weve all been brought up in a country where V8s think there king s#!t, yet imports have come along where you can pull out even more street power from about half the capacity.
Im not old enough yet to help annihilate V8ers on the stip or the track, but please, for those who can, continue to do so, your my F&*@en absolute idols.
plus what engine really does sound better than an RB? i doubt theres any comparison
Man, all the best for your RB, im sure it could hold out for a rip down the quarter.
And christ.....stop abusin people for the power that theyre makin, just cause you havent seen it in the flesh...must be frustratin for the person thats got to put up with it all.
Cheers
Easy to tell..... go to the track... if you run faster than 138mph, that will indicate the power, and shut people up...... however run like 122mph and watch the flaming!!!
Personally i'm calling shennanigans on the 500rwhp @ 18psi with a 35/40. no doubt the turbo can support the power.... but not at that boost level.
But hey stranger things have happened!! good luck at the track!
You can see its running 18psi on the dyno sheet and as for 138 mph i dont think so
maybe 132mph
Update
Finding that Optimax fuel is pretty shit
getting good then bad runs when refilling with optimax
i run just BP now and have no problems
or Vortex 98
i am going to try to run the MOBIL 1 High Performance fuel
see any difference
So far to date i have pushed 502 hp on bp 98 fuel
all fuels have been done on the same tune
apart from c16 which i modified and fined tuned
which i made 528 HP at the wheels
Not bad for the standard motor
i am taking the car powercruise and will be giving it all its got there
and if it lasts which i get some slicks i will take it to eastern creek
Wasnt this thread to try and establish who is getting big hp out of a standard engine and what the max is ?
Its turned into a wank fest.
I have a 35/40 going on a 25 with stock bottom end and im willing to bet she will pop very soon.
Only because it has been very poorly treated from drifting and playing tennis off the rev limiter.
    • The r34 gearbox is like $3400/3700 landed from Japan sometime last year.   Contact jessestreeter.com for info and quotes. From memory the navara gearbox needs input shaft machined down as I looked into a while back and there's a thread somewhere here from 2018-2021 about it. Depends on what your doing with the car maybe worth the dollars to go cd009 or a 8hp50/70.
    • VCAM doesn't really increase peak power, it just widens the powerband. So if you were giving up power with adjustable cam gears to get better low-end response yes in theory it "increases power" but otherwise not really. Stroker kit might put you in a more efficient region of the compressor map which will get you more power but at say 7000 rpm I'm not sure that much will change. The original HKS GT2530, -5s, and GTX2860R gen 2 are all roughly the same kind of turbo. If you want 600 horsepower those are the turbos you need. So 500 whp. Just expect to spend some quality time trying to figure out intake/exhaust piping. The "twin turbo" pipe is an obvious place to start. Make sure the actuator preload and all of that fun boring stuff is set up correctly. Throw a VCAM step 2 at it if you want good response, 2.8L stroker too. If you're not actually wedded to 500 whp all the time you can barely get there with -7s or Nismo R3 turbos, you just have to run E85 or race gas and run them hard:
    • It's used in the GT-R, GTST/GTT, and Z32 VG30 NA + TT versions. Nissan still makes them new, they're not cheap but they're not expensive either. Personally I would just get something direct-fit and be done with it but I'm not that handy at fabrication.
    • FS5R30A the nav box isn’t it? I did think about those. Any issues? I wondered if the bell housing off an rb30 patrol would work as they are the same gearbox but with a transfer I believe.
