Anyways Adrian
i dont know if you are having a bitch or talking good
ill let my car do the talking
Bitching mainly, just NOT about you or your car. There are some pretenders on this forum/thread. Sift through the BS and you'll be right.
Good luck with the rear end at the track - I'll be there cheering the 10's!
Adrian
Yep I agree, let the car do the talking
Awesome to see a workshop pushing a good old RB25 to the limits though, I know If I owned a workshop I probably would of done the same ... RB25 POWAH :(
yay for the good ol understated rb25 :PBJ:
Adrian
does your car select gears when your racing. i mean do they go in smooth as mine wont go in.
For me to shift i needa shift at 6500
how do u fix this problem other then upgrading to a different box
is it something to do with oil or syncros etc
Adrian
Always - want the low-down? Gimme a call and I'll pay you a visit. I wanna see this thing in the flesh! :(
Adrian
Changed fuel to c16
I gained 26 Hp without fine tuning so i can say there is a majour difference
I will be taking the car to powercruise so if people wish to have a look at the car they are more then welcome.
i am going to mainly be crusing round and might give drifting a go with this package but i dont think its to drift friendly
lol
Edited by LNEMUP498HP
NICE WORK all keyboard warriors told me my engine was gonna blow with 301 rwkw but a yr later its still fine and i thrash it daily...JMS are makin 360 kw on a standard rb25 and drift em..keep pushin it till it blows....
I will Champ Dont worry
I am gonna run it like this for a while then im going to pump the boost up to 24 psi
i am going to post some photos on the car and want to ask if i can post a video as well
where do i do this
You really have to admire the japs. to build engines that can take that much power out of a stock bottom end for that long....damn i respect them. THe RBs, the SRs.....they really know their s#!t. weve all been brought up in a country where V8s think there king s#!t, yet imports have come along where you can pull out even more street power from about half the capacity.
Im not old enough yet to help annihilate V8ers on the stip or the track, but please, for those who can, continue to do so, your my F&*@en absolute idols.
plus what engine really does sound better than an RB? i doubt theres any comparison
Man, all the best for your RB, im sure it could hold out for a rip down the quarter.
And christ.....stop abusin people for the power that theyre makin, just cause you havent seen it in the flesh...must be frustratin for the person thats got to put up with it all.
Cheers
Easy to tell..... go to the track... if you run faster than 138mph, that will indicate the power, and shut people up...... however run like 122mph and watch the flaming!!!
Personally i'm calling shennanigans on the 500rwhp @ 18psi with a 35/40. no doubt the turbo can support the power.... but not at that boost level.
But hey stranger things have happened!! good luck at the track!
You can see its running 18psi on the dyno sheet and as for 138 mph i dont think so
maybe 132mph
Update
Finding that Optimax fuel is pretty shit
getting good then bad runs when refilling with optimax
i run just BP now and have no problems
or Vortex 98
i am going to try to run the MOBIL 1 High Performance fuel
see any difference
So far to date i have pushed 502 hp on bp 98 fuel
all fuels have been done on the same tune
apart from c16 which i modified and fined tuned
which i made 528 HP at the wheels
Not bad for the standard motor
i am taking the car powercruise and will be giving it all its got there
and if it lasts which i get some slicks i will take it to eastern creek
Wasnt this thread to try and establish who is getting big hp out of a standard engine and what the max is ?
Its turned into a wank fest.
I have a 35/40 going on a 25 with stock bottom end and im willing to bet she will pop very soon.
Only because it has been very poorly treated from drifting and playing tennis off the rev limiter.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
