Max Hp Out Of Standard Rb25
LNEMUP498HP
Question, is that with the bottle, or without it?
without
i think it comes on about 3300 with nos and full at 4300 or so
when i get the ecu back
ill post two dyno sheets
one without nos and one with to compare
Edited by MR331307
i own the one ur building, hurry up and finish it! :starwars:
ahhahahahhaahhahahahaha
yes i better anounce this
i borrowed my mates plates SCRMER
my plates are LNEMUP
im building his car
it has a Trust t88
Forged pistons,rods,crank,jun pump,Larger oil sump,GTR head,LARGE CAMS,custom cooler,Hydra ECU,1000cc injectors.
will be ready in 2 weeks
R31Nismoid
where you located
i will be traveling to heathcote one day over the next few months
maybe you can come to view the car
Vic, about 1.5hours from heathcote.
But lemme know if you do head down there, and if im free ill come for a cruise.
Might even have my car back for some drag workout :starwars:
hey jason good work mate, ya always get people having a go at whatever you try, but thats life :)
u shut alot of people up runnin a 10 and now u just gotta shut the rest up with a 9 haha :)
good luck in the hunt for 9's :)
Thanks mate
if i can organise an auto or dog box
i will gain .7 of a second
to start with from what we calculated in time losing while changing gears
then a little more power and harder launch should run a 9
well what im aiming for anyway
im building his car
it has a Trust t88
2 weeks he says! i have witnesses now :)
compressor surge is caused when your cylinder head cant flow what is being pushed through it. camshafts are your answer. GT35/40 are rated for 700hp.
Just a quick question, you say you have a gt3540 - just wondering what specs as mine has the 0.82 rear and is making 480rwhp with slight compressor surge (meaning the turbo has run out of flow) and 24psi, mine also sees full boost early 4000rpms - just after a comparison with when yours sees full boost as im assuming you have a 1.06 exhaust
And congrats on the power and qtr time
Thanks mate
Does that mean you think 10.8 is as fast as it is going to go with the standard gearbox?
:P cheers :)
:P cheers :)
i think that is
if i flat change i think it will blow in the first couple runs
i am trying to find a dog box if any 1 has 1 for sale.
I was of the impression compressor surge meant the turbo had run out of flow capacity, GCG apperantly do an anti surge front cover which has small holes to help with flow. I am thinking of doing this and 66mm front wheel if it won't make it noticeably laggier
according to garrett's site compress surge occurs when the pressure past the compressor outlet is greater than the pressure the compressor wheel can supply, ie the compressor map dictates that it can supply 12psi compression in the ideal scenario in the compressor island, but for some reason the pressure past the outlet, in intercooler/manifold pipework is above that 12psi level
They are bypass holes, they don't increase the maximum flow capacity of the compressor. They are used to prevent the problem that paulr33 explained in the previous post.
:) cheers :P
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
