so the idea of the holes is
to allow some air to bypass the compressor inlet/snout and enter directly into the compressor housing ?
As you can see from the picture of my turbo below, the holes (some turbos have slots) allow the air to enter further out on the compressor blades. This is an attempt to avoid the compressor surge problem that occurs when you have a large turbo on an engine that won't take the airflow at mid to low rpm's.
:) Cheers :P
without
i think it comes on about 3300 with nos and full at 4300 or so
when i get the ecu back
ill post two dyno sheets
one without nos and one with to compare
i have just finished reading this thread, and oh my, how fun it was... everyone seems to be in the same rb25 frame of mind, where it can only push 300 odd rwkws max.. kudos to you mate, your doing exactly what id be doing if i had a dyno on hand 24/7.... see you at the track.
thanks mate
and ill see you there in 2 months
Was the motor that you just blew up stock?
Just got my 2 speed box ordered
and stall converter
should be in next week
will post new dyno graph
and be going to the track to see how much quicker it will go
Video clips havent been uploaded but will be soon when i got time
  • 3 weeks later...
Guest Rotary20B
Hello
I am new to this forum site.I would like to know what is the highest HP at the Rear Wheels produced by an Rb25 motor.
I currently have a GTST skyline and with the standard Rb25 motor and pumping out 498 Hp on 18 PSI.It is a manual skyline.I am running a Standard Motor,GT3540 turbo,Custom plenium,750cc Injectors,Hydra Computer,125 mm thick cooler with HKS style end tanks,3 " intercooler pipes, 3 "exhaust,Aftermarket coil packs.The engine has been run on the dyno about 150 times checking things and testing as i am trying to prove what the standard rb25 motor is capable of.
I am wanting to see who has made more hp.A dyno sheet is available and the dyno is on my own Dyno Dynamics Dyno running shootout mode.Intake Temps on the dyno sheet are 34 degrees and the room temp is 30 degrees.
Thanks
PS this is on Opitimax fuel.
I remember a customer of MazFix's did a comparison on shootout modes on the Dyno Dynamics dynos and it ads 25% more power over normal mode which would equal 373.5 hp on normal mode.
Interesting
but if you read off the dyno dynamics site
it states that it locks all variables in place not allowing them to be changed
the only way you get more hp out of shootout mode is putting your exhaust sensor near the Extractor manifold.Which is picked up then on the CORRECTIONS part of the dyno sheet.As well as tempertures of the day,Barametric pressure and Humidity.
If the dyno doesnt have shootout mode the variables such as ramp rates can be changed to suit different vehicles.
So i can say that your quote is wrong
373.5 hp doesnt = 130MPH
Yep Engine just got dynod
Made a total of 1231 HP
i was buying this for my Full chassis car but chose to use it in my STREET car
Don't kid yourself fool, you have no Full chasis car and your STREET car isn't registered or even driven to the strip and runs no exhaust, stop kidding yourself we're not idiots
Your lies don't impress anyone they just make you look like a DONKEY
Edited by Shibby
what makes you think its not rego`d
reason why it isnt drivin to the strip is that im from wollongong and if i break something it wil cost to much to get it back
As for the exhaust its dumped at the diff
and what makes you think i dont have a full chassis car im building
Edited by MR331307
Because your a DONKEY, its like your FULLY built spare RB25 that you post about but now your selling the stocker you post you can build it
Pretty easy to do a search and realise you don't remember your own lies from post to post
ive got the parts sitting there all ready
if you got such a big mouth and think you know everything come down to my shop and come check it out for yourself
or when i come back to the track
no need for silly remarks when you dont know me from a bar of soap
you might read this and that but i can assure you im using the standard motor and my other motor is ready for building machined and ready.
as for the race motor i have got it purchased and am awaiting arrival from it
it was assembled and dyno`d from another shop overseas
so many people on this forum can talk so much bad stuff about someone its not funny
to the people who have supported this thread thank you
to people who talk bad about the car and dont believe it
like i have stated the car is 80 % of the time at Wild 1 motorsport
go and view it
everyone is more then welcome
Edited by MR331307
ahhahahahhaahhahahahaha
yes i better anounce this
i borrowed my mates plates SCRMER
my plates are LNEMUP
im building his car
it has a Trust t88
Forged pistons,rods,crank,jun pump,Larger oil sump,GTR head,LARGE CAMS,custom cooler,Hydra ECU,1000cc injectors.
will be ready in 2 weeks
As for the rego why else would you need to borrow your mates plates? did you forget you posted that :):)
what your saying WAS true
but i was waiting on my engineers report before i could get the new Blue slip,Its rego`d now
all i gotta say is
later man
Before i go
shibby what car do you drive
Edited by MR331307
I ride a donkey
just asking
mate no need for silly remarks
See i wish to sponser or advertise on SAU
but people like you make me change my mind and lose interest
sometimes i think is it worth it to contribute and talk on these forums
they are well respected and alot of people use them for the right reasons i started off on the wrong foot but have learned to hold remarks in
Edited by MR331307
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
