Question, is that with the bottle, or without it?
without
i think it comes on about 3300 with nos and full at 4300 or so
when i get the ecu back
ill post two dyno sheets
one without nos and one with to compare
Edited by MR331307
i own the one ur building, hurry up and finish it! :starwars:
ahhahahahhaahhahahahaha
yes i better anounce this
i borrowed my mates plates SCRMER
my plates are LNEMUP
im building his car
it has a Trust t88
Forged pistons,rods,crank,jun pump,Larger oil sump,GTR head,LARGE CAMS,custom cooler,Hydra ECU,1000cc injectors.
will be ready in 2 weeks
R31Nismoid
where you located
i will be traveling to heathcote one day over the next few months
maybe you can come to view the car
Vic, about 1.5hours from heathcote.
But lemme know if you do head down there, and if im free ill come for a cruise.
Might even have my car back for some drag workout :starwars:
hey jason good work mate, ya always get people having a go at whatever you try, but thats life :)
u shut alot of people up runnin a 10 and now u just gotta shut the rest up with a 9 haha :)
good luck in the hunt for 9's :)
Thanks mate
if i can organise an auto or dog box
i will gain .7 of a second
to start with from what we calculated in time losing while changing gears
then a little more power and harder launch should run a 9
well what im aiming for anyway
im building his car
it has a Trust t88
2 weeks he says! i have witnesses now :)
compressor surge is caused when your cylinder head cant flow what is being pushed through it. camshafts are your answer. GT35/40 are rated for 700hp.
Just a quick question, you say you have a gt3540 - just wondering what specs as mine has the 0.82 rear and is making 480rwhp with slight compressor surge (meaning the turbo has run out of flow) and 24psi, mine also sees full boost early 4000rpms - just after a comparison with when yours sees full boost as im assuming you have a 1.06 exhaust
And congrats on the power and qtr time
Thanks mate
Does that mean you think 10.8 is as fast as it is going to go with the standard gearbox?
:P cheers :)
:P cheers :)
i think that is
if i flat change i think it will blow in the first couple runs
i am trying to find a dog box if any 1 has 1 for sale.
I was of the impression compressor surge meant the turbo had run out of flow capacity, GCG apperantly do an anti surge front cover which has small holes to help with flow. I am thinking of doing this and 66mm front wheel if it won't make it noticeably laggier
according to garrett's site compress surge occurs when the pressure past the compressor outlet is greater than the pressure the compressor wheel can supply, ie the compressor map dictates that it can supply 12psi compression in the ideal scenario in the compressor island, but for some reason the pressure past the outlet, in intercooler/manifold pipework is above that 12psi level
They are bypass holes, they don't increase the maximum flow capacity of the compressor. They are used to prevent the problem that paulr33 explained in the previous post.
:) cheers :P
Guest
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
