My server is down @ the Moment
I will have it running next week
And if i got time i want to put all videos on the site
The car is still running and going but has lost comp in that Cylinder which tells me rings as it also has a bit of blow by.
I did richen that Cylinder up by 2 % in the Settings of my ecu but will prob have to run more.
I think it would of lasted if i wasnt trying to make more power yesterday but yeah
The new package will pretty much be setup the Same
the only difference is im going to run 4 % more fuel in that cylinder.i can also muck around with Seperate timing In each cylinder so i will also play with that
Edited by MR331307
15 pages and no pics of broken conrods or holes in blocks. im impresed.
i have a rb30 (n/a convert) on std management and injectors (vl t bits) with meth injection making 253 rwkw witch is a fair achevment in my books now yours is more of an achevement but i dont have the abiliuty to tune mine as i have no dyno. ive been slowly steping up the power to the curent level and now have got the shits sold the thing and am going twin cam head, hope to get 400 hp out of the thing or ill cry.
good job lad. at least u setled down abit and arnt as angry now
Yeah its all good
You gotta keep Calm With some of these Keyboard Mechanics as i have learnt but yeah
Im happy with the Effort in the Motor. I WAS hopeing to get into the 9`z but yeah
gonna have to give up
lol
With the standard motor that is
OK
Here are the photos of the Engine While we are stripping it. The pistons are in Good Condition No detention Marks Or Leaning out Signs EG melting Edges.
The head gasket was a bit Stuffed.As you can see the Standard Cams are there.
Ill post somemore Photos Later and
Ill post Photos of my other Engine While Im putting it Together
With the new built RB25 engine are you changing any of the bolt ons like turbo etc? Also I gather this is more of a drag car then track why did you stick with the RB25 instead of building a RB30 which imo would be better suited to drag only
Edited by Shibby
Guest
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
