Guys,
Its time to take my car back to stock for sale.
As a result I have the following parts which are no longer needed
#1 - Fujitsubo Super Legalis R Exhaust System
This is a 3.5 inch big bore exhaust system, mandrel bent, with NO BENDS at all. Its been on the car about 6 months, and it is very quiet.
I am after $500
#2 - Splitfire coils for GTR33
These coils have been on the car for about 3 months. Replaced the standard coils because i was getting missfire above 1.2 bar. These work excellent, and have been on the car for a short period of time. They are in brand new condition.
I am after $500 (sold pending payment)
#3 - HKS style front pipes for GTR33 - 3 inch each into 3.5 inch.
What can i say? HKS copies front pipes. Paid about $400 for these 6 months ago.
I am after $175
#4 - Tomei Poncams 260/9.15 mm lift
I have had these in the car for about 3 months. They make the car sound and perform perfectly with the turbos I have. Excellent power at good revs. Very happy with these, but they will not fit in the new car.
I am after $750
#5 - Nissan Skyline GTR 33/32 POWER FC + Hand controller
Once again, this has been in the car for about 6 months. It is like brand new. No scratches, etc.
I am after $800
#6 I also have two gauges available. A greddy mechanical boost gauge in white which is 6 months old and has a cup, and a greddy electronic oil temp gauge which is maybe a year old and also has a cup. Offers on these ?
#7 Garrett GT2860R/2560R (whatever you want to call them) turbos. Used for approximately 3 months. Done very little kms on them. Boosted to a max of 1.3 bar, these turbos perform very well. On a bad tune with 1.2 bar i ran 117mph at the drags :D. They sound absolutely awesome, and i love em but I need money for the new car.
I am after $2000
#8 Catco High flow cat for GTR33 3.5" (may fit other cars also, but depends on flange/bolt up pattern)
I am after $200
I have done maybe MAX ~ 5,000 kms if that over the last 3 months, so all these parts are practically brand new.
For any offers, realise its all neg - I wont take stupid offers, because i know what all these parts are worth,
Cheers
Tommy
  • Replies 52
Posted Images
Also forgot to add that I have the original boxes that the goods came in for the following items
Camshafts (still have procam stickers)
Apexi Power FC
1x Greddy Boost gauge
That is all
Cheers
Hi im intrested in the poncams? .. where abouts are you..if your in nsw.. ill be travelling over there in a fortnight so if you still have them .. i would be very intrested in them.
Both the boost gauge and oil temp gauge are 60mm
They are both still hooked up in the car at the moment, so can be seen working.
They come with the standard japanese fitting temp gauge thingy that i have mounted in my oil cooler kit.
I'll try and locate some photos for both, but they are all white gauges
Sorry Mark,
Just saying that the power FC wont fit an R34 (which is what i will be getting :)) and is the reason for the sale of all these parts. Otherwise I would be keeping everything ;)
Quick info page for the fujitsubo exhaust
http://www.fujitsubo.co.jp/search/prod-v.p...cnamID=00000514
Interesting things to note, are that it weighs 8 kilos LESS than the stockie, puts out 94dB @ 5100 rpm, JUST LIKE THE STOCKIE.
There are also some power figures, and pretty pictures
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
