Reading through a few threads has got me wondering...
I've read that MAF is more accurate than MAP, so why have MAP at all? what application of car setup/tuning would a MAP sensor be better than an air flow meter?
I have a HKS VPC on my car at the moment, and am debating if i should go back to an Air flow meter (MAF) and get a Power FC to tune it, or get the car tuned with the HKS VPC and a Power FC. (I have a HKS FCONV in my car and no one to tune it.)
So yeah... any experience/opinions/facts/examples would be good. As i really have no idea what the differences are, and i'm sure there are plent of other people out there who don't know either!
Thanks
Andrew
https://www.sau.com.au/forums/topic/10682-map-vs-maf/
It's a give and take on the MAP vs. MAF. MAF is much easier to tune with forced induction (and cams)...but MAP(Manifold Absolute Pressure sensor) is slightly more accurate at higher HP levels and with the added bonus of being able to mount the air filter to the turbo or leave the turbo exposed like so many high HP drag cars.
I would keep the HKS VPC and get the power FC!This is just my opinion though!!
(sad, that the Fcon-v has to go! Cause Fcon-v and VPC are widely used in drag cars in japan)
MEGA
https://www.sau.com.au/forums/topic/10682-map-vs-maf/#findComment-172585
Yeah... well i'm not going for huge HP levels, around 300rwkw is about what i'm aiming at. I don't want to have to start strengthening gear boxes and diffs just yet. Maybe sell the VPC and Fcon setup to someone in Sydney who can go to BD4's... and i'll then get a Power FC and Infinity V44 air flow meter (a little bigger than Z32). Yeah it is a shame, cos i've heard the FCONV is an excellent computer if you can tune it!
Andrew
https://www.sau.com.au/forums/topic/10682-map-vs-maf/#findComment-172611
I got this from Mario (GTR.700) :(
Basically, to sum things up, AFM is the better method of airflow
measurement, but MAP is less restrictive to flow.
In short, for all out full throttle applications, such as drag and/or
circuit racing - MAP would be the best due to less complexity and
restriction.
AFM is better, as it is more capable of metering airflow and can adapt to changes in atmospheric conditions very well, and provides much greater resolution for transient throttle response, so on a daily driven road car, it would be the best.
https://www.sau.com.au/forums/topic/10682-map-vs-maf/#findComment-173001
yeah thanks for that... it's not so much as "not needing to buy an afm" it's more which one is better for my application. I can always keep the VPC and just get a Power FC and have them tuned together. But if an Air Flow Meter is going to be better then i'll go that path!
https://www.sau.com.au/forums/topic/10682-map-vs-maf/#findComment-173281
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
