  • Replies 389
Posted Images
You have to be an absolute tool to bump someone and vice versa. The day is pretty much everyone at their own pace and the fast cars seperated from the slower ones. People are pretty much told to move over for faster cars. All the track days I've been to I've never seen an incedent where cars collide, only close ones.
Bonkers, I've been sending you emails all along about extinguishers and the like.
I don't think that's ok yogi. The easiest way I think is to get a strip of aluminium from the hardware store, two holes, one at either end then bolt it to the same holes that your front seat mounts are using. So under your legs.
Then the bracket of the extinguisher bolts to that strip.
I've never seen an accident either. Also we kick the idiots off the track so as not to endanger you.
the only extinguisher in the small size worth buying is made by BFI. it's 1kg empty, 2 kg full. all extinguishers to be used in a cams event need to be metal, at least 1kg and mounted with a metal bracket. the usual torpedo shape ones people use have a fire rating of 5, the BFI ones rating is 20 so it will put out 4 times as much fire. i've shot off a few types and some of them are pathetic, the BFI one is good shit. so my advice is pay a little more and get one that will really save you or your car if needed.
my extinguisher is in the passenger side, near the end of the foot area on the door side, if that makes sense!!
fitted it in a few mins, bought it auto 1 a while ago
i wont be racing, however ill try and make it down, if i do ill volunteer to be a flag marshall, however i wont know till a few days before
cheers,
chris
I just had a set of 2nd hand GT3 porche cup slicks fitted to my spare set of GTR rims, although they are suppose to be 240's they only just fit on the 9' rims. Lets see if they last a little longer then the last set of yoka's I had!
Cheater! Double cheater!
eek.. the one I have is mounted with a strong, quick release style plastic bracket.. It's definitely not going anywhere in a hurry, but is easily removed. Is this going to be ok or is it STRICTLY a metal bracket?
The plastic bracket ones should be OK but next time (!) get a metal bracket it is a problem with some scruitineers.
For those worried about making a hole in the carpet, feel free to check out the Zed's passenger floor....you will never spot where the extinguisher used to be :whistling:
i think we may have gone a little OT here. i havent seen the regs for this event (or even if it has any) so i dont think any extinguisher is required. is it? BUT to answer the question, in nsw super sprint series run under CAMS approval the bracket must be metal, and the extinguisher mounted within reach of the driver. it must also be a minimum 1kg dry powder type. the plastic ones will not pass. neither will ones out of date. neither will the ones under 1kg. but like i said i dont think any is required for this?
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
