Item: 1995 BNR33 GTR V-SPEC
Item Condition: Good condition inside and out
Reason for Selling: Regretful sale just started a traineeship and am unable to maintain this beautifull car on my new wage and would like to see this car go to an appreciative owner. Please no test pilots!
Price and Payment Conditions: $35,000
Extra Info:
-Original black paint
-MODIFICATIONS – Ground up
- Tyres 255wide all round on 17inchx9inch 3piece Works rims
- DBA cross drilled & slotted rotors(front) brembo calipers all round
- Apexi coil over’s height & damper adjustments
- Adjustable nylethane bushes throughout front & rear
- Adjustable race rear sway bar
- 3inch exhaust system turbo’s back finished with polished cannon
- K&N air filters on custom inlet pipes 80mm airflow meters
- PWR intercooler polished stainless pipes,
- $16,000 FULL ENGINE REBUILD + $3,500 custom turbos only 4000kms old includes
- Forged pistons, rods balanced and blue printed bottom end
- N1 oil & water pumps
- New racing timing and all other belts
- Tommei adjustable cam gears
- Tommei type A cams + full reconditioned head to suit
- Full Tommei rebuild kit including thick Metal head gasket for high boost applications
- And to hold it all together stud kits from top to bottom
- To make it all happen are a pair of custom turbos capable of making and holding 1.5bar all day every day
- Running the show Apexi Power FC with the help of a HKS boost controller and blitz turbo timer
- Other features inside the car MOMMO steering wheel & shifter and a Daniels 320km/hr speedo.
Contact Details: Interested buyers please contact Shane at [email protected] or phone 0410690300
Edited by shaggy
At $35k this thing is a f**king steal and you are highly negotiable :D
If I didn't just buy a new car, your mobile would already be ringing!
Good luck with the sale dude........though I don't think you'll need it.
Edited by PHATGTR
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
