Hi,
I have a query regarding replacing the rear diff on an R32 GTS4. I have done a search and the best I could come up with was this ttp://www.skylinesaustralia.com/forums/index.php?showtopic=66537 though it didn't answer my question perfectly.
Are the GTR and GTSt diffs straigh swaps for the GTS4? I assume that I simply need to unbolt the tail shaft and axles and bolt the new diff in.
Any thoughts would be great and I don't know a whole lot about diffs.
Thanks.
https://www.sau.com.au/forums/topic/106839-replacing-an-r32-gts4-diff/
Been there, done that. Had the gears (crown wheel & pinion) swapped from a Stagea diff onto the centre of my GTS4 diff. I'm guessing, along the lines of what Duncan said, the same is the simple solution when using GT-R / GTSt diffs.
