Hey all
(R33 GTS-t Series 1, lowered, 19" rims)
I have noticed lately that my right hand side front tyre is rubbing really bad on the wheel arch when i turn sharp or the car is on a slope, it has been doing this for a while but its been really bad the past week.
Now, when i bought the car, the guy said the front suspension is adjustable... i do not know how to tell this!
When looking in the engine bay i obviously have the big cylinder-looking bulges either side where the shocks etc hide inside... and looking at the very top in the middle, theres a little bit sticking out with what looks like a groove for a flat-head screwdriver, and this has a red rubber thing around it with numbers on it, 1, 2, 3, 4 etc, i dont know jack about suspension and was wondering if this is where you adjust it, or something else? And was the guy i boughtthe car off just bull$hitting me when he said it was adjustable?
I was hoping that raising the front by 1cm or so would get rid of my tyre rubbing problem.
Sorry to sound stupid, but its technical ground which i have never crossed before...
ok the only way you can adjust the height on your car is with different springs or coilovers. you might have coilovers on the front of your car but i think you might just have damper adjustable shocks, can you take a pic of the wheel arch with the tyre off and the top of the strut towers in the engine bay. with coilovers they are height and damper adjustable, damper adjustable controls the rebound rate of the shocks which you can set on soft or hard or somewhere in between. here are a few pics to tell if you have coilovers on the front or not. the first pic is the threaded sleeve on the coilovers which adjusts the height. the red circle in the second pic is the damper adjustable control.
yep, to find height adjustment, look at the spring seat (the cricular platform that the spring sits on) and see if there is thread there
if there is thread, unlock the locking collar (if there is one) and then wind the spring seat down.
some coilovers dont have height adjustment at the spring seat, but have locking collars underneath and a helper spring though, but still, lower the collars and will lower the car, raise them and it raises the car
  Freddy Kruger said:
ill trow in a n00b question too.
if the coilovers are hight adjuable, how do you get eac side the same height? just measture between point on it? or isnt it that simple?
thanks
Clean teh collar with a rag and make a marking on the collar (with a magic marker) so you know how much you turned the collar. ie you turned teh collar 1/4 of a revolution. Do the same for the opposite shock. It the car was level to begin with, it will be level once lowered more.
Mind if i throw in a noob question too!
If the damper adjustable is on top of the coilovers, how do you adjust the damper rate for the rears?
Are there any other ways instead of taking the coilovers off!
As for damper adjustment.
Am I to understand it starts from left to right.
I have JIC Coilovers and they have the adjustment in the top, driven by an allen key.
So soft is full left and it increases as it's turned clockwise, or is it a hit and miss deal?
Sorry maybe i shoulda made my question clearer.
If the damper adjustable is on top of the coilovers, how do get to the top of the suspension for the rears? I cant seem to get to it from the boot as there is the metal chassis around the area.
Is there a way of getting to the damper adjustable knob without taking the suspension off?
Not all suspension is damper adjustable but those that are commonly have either an adjustable knob down low (near where it bolts on to a lower suspension arm) or on top like your fronts. To access this though (if there are no extensions) you will need to get under the parcel shelf which is where the top of the strut is bolted.
Or if you're really lucky and have the latest electronically adjustable ones that Tein, JIC, Cusco and several others are putting out, just push the button on the control unit.
cheers
Tip: To adjust the height of your coil-overs (if you have them), the easiest way to turn the collars is with a "C Spanner" (See attachment).
If one didnt come with the car, you can get them from most Motorcycle shops (Most bikes use the same form of adjustment for their suspension)
I tried all sorts of ways adjusting mine (hammer and flat head screwdriver etc).. The C-Spanner will save you heaps of time and energy.
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
