Afm's are a tricky beast to check, the only way to do it properly is with an oscilloscope, and not too many people have them. In any case if ur idle speed is going up & down ur going to have trouble getting reliable readings, though it should give a uniform wave if the idle variation is constant.
I'd actually start looking for vacuum leaks, because that's more likely. I had an intermittent idle issue on my 33 & it would do just what u are saying. It turned out the vacuum hose to the boost gauge sensor was splitting where it was connected to the plenum & would sometimes leak causing the idle issue.
The problem is when you have a leak is that the engine is then sucking in air that it's not measuring from the afm. The computer gets confused & varies the Idle air controller valve to compensate, which it finds very difficult when there's an air leak it doesn't know about. You should check for leaks mainly between the section on anything between the throttle body and the the intake ports of the head. Vacuum hoses, injector seals, gaskets & that kind of thing, even a small leak in this area will have the biggest effect at idle.
Also remove & clean the IAC valve & the AFM elements with a can of carburettor/Throttle body cleaner (also known as a decarbonising spray) as if either of these are gunked up & dirty it can cause problems too.
Hope this helps u out
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
