HEY GUYS FOR THE LAST COUPLE OF DAYS IN MY 96 SYLINE THE ABS LIGHT ON DASH WAS ON WHOLE TIME AND I FIND MY BRAKES AREN'T THAT GOOD TOO.I CHECKED THE BRAKE OIL AND ROTORS AND BRAKE PADS EVERY THINGS IN GOOD ORDER.
JUST WONDERING WHAT THE PROBLEM COULD BE AND WENT TO BRAKES PLUS THEY HAVE NO IDEA.
ANY SUGGESIONS OR ANYONE KNOW WHERE SHOULD I GO TO FIX IT?
https://www.sau.com.au/forums/topic/106907-abs-light-on/
your braking performance should only be affected if you are doing hard braking, ie under normal conditions if ABS was working it would activate, as its only active when it detects brake lockup and it doesnt actually help normal braking under normal conditions. your best refernce would be to goto a nissan dealer to get it sorted
https://www.sau.com.au/forums/topic/106907-abs-light-on/#findComment-1972953
I've got the same problem.. not sure what it is.. getting it checked out next week and will post the resolution.. It's probably just a busted sensor or something.
Edited by Primordial
https://www.sau.com.au/forums/topic/106907-abs-light-on/#findComment-1975218
  • 6 months later...
  • 1 year later...
  • 3 months later...
  • 5 months later...
I find that is's better to have less electronics as possible on a car to minimise failure rates. If Nissan were to build a new skyline or silvia NOW with no ABS, no SRS, no HICAS, no tiptronics, no electronic handling gizmos, I'll be happy to buy one as soon as it was released. lol :(
Just base electronics would be fine like ECU.
Edited by teng
https://www.sau.com.au/forums/topic/106907-abs-light-on/#findComment-4341482
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
