Hey guys, got new rims and tyres, so decided to sell my Work VS -KF's off my R33 GTS-t.
(Came off S15 200sx before that)
They are silver with a chrome/polished lip.
Sizes are:
18x8.5 +40 front
18x9.5 +45 rear
The fronts require 5mm spacers each side which are included to prevent the tyres scraping the guards.
All 4 of them will need new rubber as there is peanuts left, hence why so cheap (I dont have time or licence to organise new rubber).
And yes theres gutter rash on them also, any keen buyers can come round for a look.
Located in west side of Melbourne.
PM or email: [email protected]
$1400 obo (+del. if interstate)
SOLD
Pic of front.
Pic of rear.
https://www.sau.com.au/forums/topic/106941-vic18-work-vs-kf-off-r33-gts-t/
are there spacers for the rear? I tried a set of a mates 18inch rims on my 33gts-t that were the same widths except ALL the offsets were +45 and the rear rims hit my caliper??
would have only needed 2-3mm slip on spacer to fix....but just asking. Or maybe the spoke shape is different enough to clear the rear calipers?
Yo Abcent, i think the way the spoke design matters.
The spacer is for the front (+45) i tried my new rim on the front the other day (+13 and it needs a 10mm spacer to clear the brakes). Its actually the same rims but different dimensions (Plus VS-KF i know have different spoke designs 2 or 3 i think).
I think these rims need a spacer to clear the struts? :domokun: ? or the guards, i dont think its for the brakes.
Ive actually got them on my car now without the spacer cos unless my lines the only one but the stud threads arent all long and i was worried with the amount of thread left after the spacers put on(Maybe im over cautious).
So i suppose it cant be brakes, but when i turn my wheel a bees d!ck away from full lock, i get scraping, which sounds like the inner guards actually.
[EDIT] Went out to have a look (in the dark though) and the way the spoke design is matters, if my spokes didnt bow out and where more 'flatter' they would hit the brakes or if the rims where +45 offset id say theyd hit the brakes too(they just clear them).
Looked at my new rims and the spoke design is alot more flatter than the ones on my car and both are VS-KF.
Hope that helps.
So if any1 reading this has 2x10mm bolt on spacers lying around PM me i wanna buy em!
RIMS ALSO SOLD PENDING PAYMENT
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
