I am just wondering what turbos will bolt on to an RB25 without changing the manifold?
What about all of the other stuff that connects to the turbo?
Compressor inlet
Compressor outlet
Oil supply
Oil return
Water supply
Water return
Dump pipe
:P cheers :P
See i dont know much about turbo upgrades. Will i need to upgrade all that stuff as well?
If you get your standard turbo high flowed everything will fit back on as standard. Nicley defect resistant as well. We use lots of GCG ball bearing high flows (not to be confused with the cheap plain bearing high flow jobs around). Good for 275 rwkw if you have the supporting parts.
:P cheers :P
But 2k, is a lot for just the guts of the turbo getting re-done.
What kinda supported modz would you say to get?
ATM i have
- 3" from teh turbo
- Pod
- CAI (within a week)
- FMIC
- Dual Stage BOOST Controller
Planing on a powerfc very soon.
What else would you suggest?
