hey guys,
My gearbox is making a grinding/whining noise at idle when its in netrual.
When i push the clutch in, the noise goes away.
What happened was, i had everything out, so all the oils were drained.
I put the box and engine back in, and for a while i let the engine idle while i was sorting out small prblems etc.
the thing is there wasnt any oil in the box or trasnfer.
I never drove it with out oil, it just sat idling and after a while it started making the noise.
even now with new oil in everything it still makes the noise, i though if i drove it slowly sround the block the oil would spash up on what ever is grinding and stop making the noise but it hasnt stopped.
have I damaged something??
steve
Its to do with the thrust bearing or spigot bearing or whatever its called. There are two cases. one where it makes a noise when the clutch is pushed in (which is what i had) and the other is when you have the clutch depressed and it makes noise. You need to remove the clutch and box and replace one of the bearings :P
Symptoms point to it being the input shaft bearing, mine makes quite a racket after the box has warmed up. When the box is in neutral and the cluch is not depressed the input shaft is turning, when the cluch is depressed the flywheel is disconnected from the gearbox. You might want to get onto it before the hardening is worn off the shaft.
Sorry but that information is incorrect.
The input shaft is always turning, whether the clutch is depressed or not, end of story. The spline feeds into the flywheel which obviously is bolted to the crank. When the motor is turning, so is the input shaft :)
Noise when in neutral and clutch out, thrust bearing
Noise when clutch is either in/out, driving through gears = most likely input shaft bearing = rebuild not too far away.
Noisy thrust bearings are pretty common, few hard launches seem to get em grinding away. If it bothers you that much, you can remove the box, and just replace the thrust bearing and throw it all back together. Honestly I would keep driving it until the clutch is fubar, and replace the whole lot in one go. Thats what I would do, doesn't mean its correct way to approach it haha.
I think you will find you have it wrong here .
When the car is stationary and engine running the input shaft is turning but as soon as you depress the clutch it will stop turning in a few seconds .The flywheel still turns, the pressure plate still turns but the clutch plate is not touching the flywheel and the pressure plate so its not turning !!
When the car is moving then yea the input shaft is always turning the same speed as the engine but as soon as you press the clutch in they can turn at different speeds as they are not touching any more.
Say you are going 120 kmh and the tacho is showing 3000rpm clutch in the tacho is now 800 rpm or whatever the iddle speed is set at . Thats because the the clutch is not touching the fly+ pessure plate .
I hope you can understand how it works now ..
Now to FHTR32's problem . It sounds like when you started the engine and you had no oil in the gearbox the input shaft bearing ran dry and you did some damage there thats the reason it stops when the car stationary and clutch in ( as the shaft is not turning ) To test if thats it drive at say 60 kmh down a hill somewhere in say 4th gear then put your foot in the clutch if the noise is still there thats probably it then take it out of gear and see if the noise goes away but you still have to have the clutch pressed in .
If the noise is very bad you should take the box out and replaced it , if its a very mild noise leave it until it gets worse .
When you do a clutch you should always change the thrust bearing too . I assume you a skyline so it will have a spiggot bush not a bearing .
SH!T!!!!
i just remembered!!!!!!!!!!!!!!!!!!
the spigot bush is in the center of the flywheel right? and the tip of the shaft sits in the middle of it? mine didnt have one!
steve
Yes thats the one and its brass, How can you say that yours didnt have one ? IF it didnt you should drop the box out and put one in there . $12 for the bush and 3-4 hours work to R+R g/box .
I'm with wrxhoon on this one.. :)
If the spigot is not there do not drive it as there is no support for the input shaft.
You have most definitely damaged the input shaft bearing if not furthur down the line.
A mate of mine accidently forgot to remove the auto spigot and use a manual item.
We replaced the spigot, instantly it was better but still very grindy and vibraty. :D
His box has since been driving around for ~1year, still hanging and grinding in there. :P
We replaced the spigot, instantly it was better but still very grindy and vibraty. :(
His box has since been driving around for ~1year, still hanging and grinding in there. :)
wonder who that could be :(
Such a simple thing, can mean a wasted afternoon, and a few skinned knuckles.
Im amazed how tough the r33 box is though. Around a year of abuse behind the 3lt, with shagged bearings, and it still hangs in :)
Edited by Bl4cK32
dude. oil is your friend :P
with it ideling in neutral the gears in the box are spinning at engine speed!
the transfer case will be sweet as it only spins as you drive
chances are youve damaged a bearing in the box from no oil. if it makes a knocking type noise. one of the roller bearing "cages" has broken.(the metal cage that seperates all the ball bearings in a roller bearing)
did heaps in my old dr30. not from no oil just revs.
the noise will only get louder. so start saving for a box :)
sorry to put the scare on but the reality is it is dying now :D
great, thats exactly what i needed at this point in time. the freaking piece of crap isnt every registred yet.
stupid thing is i noticed it didnt have the bush, so i checked the shop manual and it didnt mension anything about a spigot bush or bearing, so i just assumed it didnt have one.
was gonna ask on the forum but i completly forgot.
also, when i took the box and clutch out it didnt have one, so the owner in japan must have been driving around with it like that. except it didnt make this noise till after i pulled it apart.
dam it :P
steve
the noise will only get louder. so start saving for a box :D
ps.. the bloody input shat bearing is the last to go. its quite large.
the first one to go is the countershaft bearing on the sandwich plate. or the input shaft gear itsself.
this is speaking from experiance having poped 12 fj20 boxes over the past :)
by the sound of it youve iether galled a mainshaft bearing(most likly)(the ones the driven gears spin indipendantly on)
or done a sandwich plate countershat bearing.
either way. its easy to check anyway. if its noisy in 1st. its the counter bearing.
if its noisy in 2nd or 3rd its the maishaft ones.
if the noise goes away in 4th its the input shaft gear(very unlikly)
other than that just drive it and find out what gear its noisiest in. try to keep the revs at around 2000rpm in each gear so you can acuratly guage the noise
hpoe that helps :)
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
