Item: 1993 Nissan Skyline RB25DET
Price and Payment Conditions: $17000
Exterior:
- 18" XHP Chrome Invader Wheels
- Veilside kit with Bomex front bar
- removed stock wing giving fin effect on boot :P
- 3’ exhaust turbo bak 4’ cannon
- Carbon Fibre bonnet
Interior
- Leather Autotechnica gear nob/cover and handbrake cover and handle
- White dials with Red and blue numbers/ lines
- Custom sparkle blue dash
- Kicker 12" sub
- Kicker 6.5 Splits
- Pioneer Tweeters x4
- Pioneer 6.0 splits (on parcel tray)
- Sony head unit (MP3)
- Custom SKYLINE floor mats with metal SKYLINE badge on them
Performance
-FORGED PISTONS
- HKS pod filter
- Turbosmart dual stage boost (switch in car)
- Go fast bits BOV (adjustable)
- Blitz turbotimer
- 3.5" turbo back exhaust
- Piggy bak on ecu
Extra
- 110000km
- New Rubber
- MONGOOSE SECURITY
email me, call me, msg me,
[email protected] 0439466177
cheers Nic
Edited by NIX33
https://www.sau.com.au/forums/topic/106998-veilside-r33/
  • 2 months later...
  • 2 months later...
  • 1 month later...
