Any one seen/purchased these rims?
http://www.modyourcar.com.au/product_info....roducts_id=4428
They look to be alright, very similar to the nismo ones (and at an affordable price) which im looking for. Looks to be a set offset, so will the +30 17x9" for the front and +15 17x9.5" for the rear fit a r34?
https://www.sau.com.au/forums/topic/107019-nismo-lm-gt4-rims/
its probably as good as im going to get on my car budget, they dont look too different from the lm's which i will never be able to afford. The offset mentioned on the site, do you think they should fit the skyline?
thanks for the replies; i guess 17x9 (all round) should do the trick then. Will probably have to lower the car at the same time also....so it wont look too goofy.
Edited by RyanN
17x9 +30 offset for the fronts you will most likely run into problems when u lower it. ideally you would want 17x8 in the front and 17x9 in the rears with a +30ish offset. 17x9.5 +15 for the rears will stick out like dogs balls and will rub ur guards when you try lowering ur car.
U might wanna chk these out as well look much better IMO
http://www.nissansilvia.com/forums/index.p...pic=117430&st=0
would the different tyre widths screw with the HICAS ?
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
