I have been reading so much about the split dump pipe and how they are superior to the 3" dump pipe. Statements like "they reduce turbulence when you are on boost, therefore reducing backpressure", "10kw gain", "should notice a big difference in the top end of the rev range". These statements and theories behind it sold me. So I though I would give split dump pipe a go.
Since I already had a 3" dump, I decided my cheapest option would be to modify it to a split. The idea behind my design would be to keep the wastegate and turbine gases seperate for as far as possible. This would reduce as much turbulence as possible on the turbo. I made a seperator in the recess of the turbo which keep the gases seperator through to the dump. The split pipe then joined just before the cat. See my pics for the mod
results:
First design suxed: My seperator was to thin (1.4 mil) and the wastegate gases bent the metal and my car actually went worse.
Second design: I fixed the seperator with 4 mil metal. Now for the real results:
The origianal 3" dump used to drop off acceration at about 6.5 k. The new dump did not, it actually increased in acceration. Very nice.
I noticed better acceration throughout the full on boost range. But mostly after 6K, this showed the biggest gains. FYI: I was using stock boost i.e. no bleeder. I was hitting about 9.5 psi
3rd gear seemed to be the real winner hear. I noticed a really Big difference in acceration in 3rd gear. usually when I drag a car if they accerate the same as me in 2nd then my third is slighty better. But not now 3rd really pulls now. I got to test this out on a maloo ute, and a silvia. Both where slighty slower than my skyline in 1st and 2 but 3 I pulled away very quickly. 3 cars length in that gear alone. I reckon without the split maybe 1 car length if lucky...
On stock boost (9.5) it feels like it accerates quicker than when I had 11 psi with the original 3" pipe.
Split dump pipes rock!!!!
https://www.sau.com.au/forums/topic/107044-split-dump-pipe-success-story/
I wish I bought a 3" split from the start. Oh well I got to practically see the difference between the two. When I went down the quarter I got a 14.9 on my stock car. With stock boost and the full 3" exhaust with split dump it should be in the 13 easily . I ran a a 14.051 with the original 3" exhaust and 11 psi. And this feeels noticably faster.
i disagree, you will need around 200rwkw and a fairly good setup car to run 13 flat
Nah. I reckon a nice average power 160rwkw from 4000rpm to 7000rpm will cut a high 12. The old R33 did 13.3's @106mph 2.3 60ft with that power. A 2.1 60ft would have nailed a 12.9 pretty easy. Thats a car with that average power and a peak of only 175rwkw. 205 tyres too.
Hey guys, I run one of these split dump & front pipes which I purchased of CES about 2 years ago.
In my opinion, they are awesome! My car spools pretty quick, this is on a standard R33 GTST turbo on my RB25DET.
Other mods include:
FMIC
Exh cam gear
Turbo back exhaust (obviously split dump & front)
PFC
Bleed valve set @ 13psi
Pod in box with CAI
Hard pipe between turbo and AFM
If you look closely at the graph, it makes 100rwkw around 2850rpm
Just click on the attatchment to view it, it will def load up. Sorry bout the quality, but dont ever lend people digital cameras, they come back not working even though they were well looked after???
I recently bought a split dump pipe from BTMBL and spend $450 thinking its good and better than the others on the market.BUT unfortunatly it was a unproffessional job the welding were shit and i had to grind them and was not a direct fit had to modify front pipe because didnt fit the cat stright and it was 2 to 3 inches away from the straight fitting. After all that i thought i will at least feel a big gain that i feel but at the end its nothing big.Only difference is it comes to boost quicker.
I felt a noticable difference with my split dump and so have others. So it seems you would have a problem somewhere else down the line. Possibly the rest of your exhaust and cat is std or maybe your in RR. The split definitely works and you should atleast notice a difference after 6.0k....
I didnt say it didnt make any difference it made a diiference but not as much as everybody talk here....I had a full bell mouth dump pipe and 3.5inch system but i actually chucked it on the dyno today and found out its only a 4KW gain. This was done in a one of the best work shops in melbourne and everything was done properly.SO PROVED NOTHING WRONG WITH THE CAR OR THE EXHAUST SYSTEM.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
