I have been told several times that there is a speed limiter on stock standard skylines. First i was told it was at 180, then when i exceeded that speed limit, i was told it was at 200...
Anyone have an answer for me? Thanks heaps...
https://www.sau.com.au/forums/topic/107086-stock-speed-limiter/
i reckon i was pushing 200... i wasnt near the top speed for my car, and i went far past the 180 mark on the speedo...
anyone know how i could physically tell if i have one or not without going 200k's again?
Edited by DRD-00F
the most common way of removing the speed cut is to cut wire #53 (its a yellow/green wire).
you could look at the wires from your ecu to check if it has been cut.
a 'speed limiter' or 'speed cut' works by cutting the fuel supply. its has the similar effect to the driver lifting their foot off the pedal. your power will usually kck back in at round 170km/h.
if u want to know the speed ur reaching, drive with someone that has a speedo that goes further, ie, to 240 or watever and measure off them, (though their speedo will probably be inaccurate as well, but at least u get the idea).
Edited by soon2b33
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
