www.otomoto.com.au have a big selection of new KKR turbos at relatively inexpensive prices... check them out... I guess it depends on your want and need for the turbo upgrade to produce and on your supporting mods...
Cheers
Edited by QUIKBLADE
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1978469
Gee they look ok. I guess you have to get new oil and water lines and the dump pipe section. Not bad prices there though.
Hopefully this will bring the prices of other turbos down - such as GCG turbos.. I would buy one of those if they were only a grand.
Edited by benl1981
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1981407
Looks like good value - but are they ball bearing??
They do look good quality tho.... for $899 plus $149 for a dump & some cut/rewelding of my current dump pipe, not too shabby at all.
Edited by bwilkeson
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1982642
There is an R32 that HPI are building that uses a KKR 480 turbo. They said that it was a plain bearing type, and needs some minor modifications to get it to fit but the dump pipe that they have on their site makes things slightly easier. They were quite happy with it though, anyone else have experience with these turbos?
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1982970
Mate keep in mind that if you're upgrading your turbo then you'll need the following at an absolute minimum.
Fuel Pressure Regulator - $200ish
Fuel Pump - $250'ish
Aftermarket Fuel Management - $700ish
Tune - $300ish
Intercooler - $1000
Lines/adapters for turbo - $300ish
Installation for all - $500ish
Now that's just so the thing runs. Anyone doing a proper turbo upgrade would get the following.
Fuel Pump
Aftermarket Computer
Intercooler
Full Exhaust
Injectors
Induction
Boost Control
Clutch
Tune
which will take the cost close to $10,000.
You sure you know what you're getting yourself into?
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1984564
Will some people already have the powerfc. I'm currently getting around 175rwkw and my injectors are only at 70%.
So I reckon I could get about 210rwkw without even needing a fuel pump upgrade.
To get to about 240rwkw I reckon I may be able to get away with a new pump and FPR.
Clutch is a nissan patrol one that feels pretty strong at the moment.
I think 220-230rwkw is down the track eventually what I'd like to safely have. Maybe wouldn't need a new AFM for this.
Even 170-180rwkw makes a pretty fast street car..
Tune - $300ish
Intercooler - $1000
Fuel Pump
Intercooler
Full Exhaust
Injectors
Induction
Boost Control
Clutch
Tune
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1984599
Got all of that gear ready for the turbo (less injectors, wont get them until I buy a turbo)
Fuel Pump
Intercooler
Aftermarket Timing Computer
Full Exhaust
Injectors
Induction
Boost Control
Automatic Oil Cooler
Tune
Ive done the right thing and got the supporting mods ready and installed, tuned to 160awkw at 12psi on my 4wd auto Stagea. But time for a turbo.
Good value - would they last a few years these KKR thingies? Id need to modify my current dump pipe, but for $1100 plus new oil lines (dont use water lines with KKR) and install, plus then new injectors and retune of SAFC/SITC and boost to 15psi, still as cheap as getting a hiflow turbo.
Researching further.............
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1984615
  benl1981 said:
light switch means laggy doesn't it
:confused:
What happens when you turn on a light switch? The light comes on straight away.
So I'm sure you can see what "on like a light switch" means.
Also, is it just me or are there three different users all posting the same replies in this thread?
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1987532
Cheers
I submitted a post today about KKR turbos got some interesting answers check posts for -KKr and Monsta turbos, anyone used these any good? alot of mods needed to fit these sort of cancels out the money you save
sorry dont know how to include the link
Im also thinking of an upgrade but not sure what to get i was thinking maybe 2835r Im still pretty new to this so dont know whats needed, engines stock, stock cooler, heavy duty clutch, split front dump and 3" exhaust on the way, saving for powerfc cars of the road at the mo was thinking of doing the full RB25/30 thing but from what Ive heard lately thats beyond my projected budget so im most likley either going to rebuild or drop in another stock engine so all I really want is a bolt on solution thatll give me a bit of extra pwr without any more problems, so if I leave the engine stock what turbo would be best?
Edited by BOVed
https://www.sau.com.au/forums/topic/107094-turbo-upgrade/#findComment-1987542
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
