Hey guys.
Need to get rid of this stuff asap. parents are cracking it for taking up too much garage :)
hehe
All parts are in Melbourne.
GReddy Electric Temp Guage (Comes with all you need except the sender) $100
GReddy Electric Oil Pressure Guage (Also comes with everything except the sender) $160
R32 Callipers 4 Piston Front and 2 Piston Rear $350
Floor carpet $50
Rear Seat (92' model) (1 small cig burn) $50
Rear Bar (gunmetal) (Drivers side reverse light missing) $50
Boot lid (holes from standard spoiler) $50
Standard Shocks and Springs $150
ABS Unit $100
AC Compressor $80
Pics of guages can be seen on the nengun website, they are white faced with memory/peak functions. in perfect condition. i think senders can be bought through autobarn, defi senders also work, can be ordered from japan for about $40 or so.
Open to reasonable offers on everything. ALL MUST GO NOW! :D hehe
Everything is ready for pickup.
Call me on 0404049723 if you wanna enquire about anything.
Cheers guys.
Steve
Edited by Memph
https://www.sau.com.au/forums/topic/107104-greddy-elec-guages-r32-bits/
dont have pics of my actual guages, but they are in perfect condition (no scratches on face or anything like that) and are the same as these.
CLICK HERE ;)
As for the seats, they are out of a GTSt
Cheers
  • 3 weeks later...
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
