hey guys n gals
the other day after turning my aircon on (18 a/c on) it was cold for about 5 mins then just started to blow hot air ??
then i got home turn the car off for say 15 mins then turned it back on and it blow Cold ??
then the day after same, cold for maybe 2 mins then hot now it only blows hot
i think the compressor is working as when the turn the A/C on the i hear the sound and the revs increase slightly
but the pipe going into the fire wall is not ice cold as it should be
help !! bloody Melbourne it really HOT
https://www.sau.com.au/forums/topic/107108-air-con-problem-r33-help-help/
Mine was doin the exact same thing!!
I had a faulty 'air intake sensor'
Id recommend doing a diagnostics check, see what that comes up with...
In my circumstance, it said all sensors fine....However it displayed a reading of -5 degrees on the air intake sensor...
Now obviously the air goin in isnt that cold..
Id put my money on that, as ur symptons are identical to what i had...
how did you fix it ?
did you take it some where
costs ??
Cleaning the sensor is pretty easy.
Firstly, find the post on installing a head unit, this will show you how to remove/loosen the dash.
2) Where you have that little grille in the dash, next to your antenna-control button, on the inside of the dash piece, there is one screw holding the sensor to that grille.
3) Disconnect the rubber hose from it. (should be very easy, and it could already have fallen off)
4) Unscrew the sensor assembly, admire the dust-coated wire
5) Blast it with compressed air or contact cleaner.
6) Admire shiny clean sensor
7) Reinstall and test with the dash apart.
heh, sounds like my aircon
used to start cold and then blow hot air, or just blow hot air
there was also a bit of vibration/noise
i think piping the or some part of the aircon system was lose
i got my mechanic to tighten everything up
and now she goes great!
I did this on sat but hasn't really help thanks for the tip though
oh well might just have to take it to someone
Randy,
I dont believe that the sensor with the grill on the dash, near the antenna controll is the air intake sensor..
Thats the "inside air sensor". (i may be wrong)
Not too sure where it is exactly tho...
I took mine to an autoelectrician...
2 actually...
The 1st one couldnt find the problem, the 2nd had a fair bit experience with imports and their air systems.
Got recommended to the place by an importer...
Paid $240 tho.....
But then again....ur problem may be different....(just saying it has the same symptons)
Have u run a diagnostics ???? What that say?
  Notski said:
Randy,
2 actually...
Paid $240 tho.....
yeah i have run the diag, seems to be all ok apart from the sunlight sensor but dosn't that read funny most of the time ???
when they fixed the prob did they tell you what it was ???
  Spook33 said:
hey guys n gals
Ive got the same problem in my 33 thought maybe it just needed a regas if you figure it out post it it would really help
Depends if ur car is in the shade or sun??
Check the individual temperatures of the sensors...
Whilst in "Diagnostics Mode" push "HOT" untill "5" appears on the display...
Then Push "AMB" once to display the 'outside air temp'
twice to display the inside air temp
three times to display the suction temperature
4 times to disaplay the refigeration temperature
See if the temperatures given for each sensor seem logical ??
Ie. Mine said the outside air temp was -5 degrees.. (which was obviously incorrect)
And had a faulty "air intake sensor".......Beacuse the air-con system thought the air was so so so cold outside, it would stop cooling after some time....(Just like urs).
You can pull apart the dash etc, find the sensor... put it on a multi meter etc, see if its workin if u like, if thats the problem replace it...
Or if ur lazy like me take it in to an autoelectrician...(Tho, id see if there are any caryards in your state that deal with imports, and see if they reccommend any autoelectricians. (Normally these places are more experienced in imports)
how do you get to diagnostics mode?
  Notski said:
Randy,
2 actually...
Paid $240 tho.....
True, but it's a sensor of the inside air, so I think it's relevant. If the A/C thinks it has reached the desired temperature, it will stop cooling beyond that temperature. If it thinks the cabin is -5 degrees, then sure, it'll blast hot air to bring the temp UP to 18 degrees if thats what he's set it to.
To everyone else: We're talking Series2 R33, and everyone else is talking R32. I'm not even sure the diagnostics on the A/C unit are the same button-combo on the R33?
Edited by RANDY
Hi
For those who are having trouble with their A/C listen up as this is the second thing i have fixed my self in the last six months :/ bloody annoying as its been damm hot !!
anyway as is stated above bloody A/C went crazy then just stoped working
last night however my mate and i decided to give it another crack to see if we could find the problem
firstly thought may have been sensor but diagnostic confirmed that they worked fine and didn't think it would have been the compressor it self as at one stage it was working fine then i wouldn't then it was again and so on and so forth which turned me away from a fuse as it would have just gone and thing wouldn't have worked at random times
Sooooooooooo thought i just look at every thing i could possible get to with out out taking my car apart which brought to the relays (blue and white things) in that box thing where that battery terminals are ( what ever you call them) took the A/C one out looked fine but thought i'd just swap it with the fan one and bobs your uncle the A/C fired up straight away
sooooo my advised to any one who is having trouble to try this as it have cost me shat loads more to send it to some autoelec
by the way does anyone know how much a new relay is ???
  • 11 years later...
My clutch slips/plays up when I turn my aircon on, the revs drop a little but my actual clutch doesn't engage or disengage properly and it's really pissing me off! I hardly ever use aircon but with summer here and the Perth heat, I might need it for them extra hot days! Anyone know what's causing this or how to fix it? I know it's not my clutch, I just installed an Exedy HD clutch about 2 weeks ago, cheers
