guys i was IRC last night talking to sp33dy about it....
As you probably have seen the old website doesn't exist any more. The account was set up by a friend
of sp33dy and don't think it was legit. Anyway there are two DNS (www.mayfield.edu.au and www.r31skylineclub.com) pointing to the one IP address now (203.63.53.121),
and the IP for R31 Skyline Club pages dont exist currently!
Be interesting to see what happens from here
but I think they've lost that IP for the club but still have the domain name. Hopefully they can fix something up with free webhosting still?
How come I didn't see this thread earlier? :D
Well here's the news people, I have the entire site backed up, none of the info is lost, the inconvenience is a pain in the rear, but we are onto it, and will get things moving as soon as we possibly can.
Sypher Dyas we need way more space than we can get for free from spaceports, we need at least 150meg storage.
This isn't a problem, we can get the space, it's just that we weren't expecting to have to organise anything in such a hurry.
I had to send out over 450 emails telling people not to freak out.
In the meantime, we have set up an emergency board for people who can't live without postwhoring, and it can be found at
http://pub98.ezboard.com/br31skylineclub38428
We will have our old forums back, and all is not lost (as has happened many times before :D )
We will try to keep you updated, and thanks for your patience and understanding.
~K
O.K, after a bit of hard work, we're back on line, and upgraded, with sexy new look forums.
The URL to the forums has changed, but please don't bookmark the forums, we need you to go in through the main site so that you can be kept up to date with any breaking news.
See you there :P
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
