Cruise Friday Nite 4th March
ax53b70p25
 Share
Yeah will try and make a few copies and dish them out next time i go for cruise (too big to email 256 meg)_ R u the crazy driver in teh 4 door 33 htat was in front of me for a little wile? -- You got to watch those blind corners man!!!!!! Scared the shit out of me following you at one stage coming down nortin summit ... Thought you were going to come unstuck! fat cruise hey!!!!
YE IM THE 4DOOR oops caps ...
use a video compresion utility or even dowload Video Studio 8 demo and it will work
only time i felt like comming unstuck was when i pulled over and let all the other gus past ;)
i went nice and hard up norton summit rd was right on pete :D
  • Replies 64
guys PLEASE don't put my number plate on the forum!!!!!!
if your'e gonna distribute the vid can you block my number plate please, not into too many ppl knowing about it.
OH by the way I backed off on the home stretch from norton summit to wait for the rest.
um that would go without saying if plates couldnt be removed (due to lack of video editing skills) there would be no video PERIOD
Sorry guys havnt been on the net in a while... Dont worry im not going to post the vid on the forums (way top flippin large and i dont want that sort of recognition if it is compressed and put online). I will make some copies when i cbf and will distribute when i next c people for such a thing-- thinking about going out to drifts on sat (to watch).
Madaz there is a bit which shows u going into a corner a lttle hot hit the brakes and almost run out of road on the wrong side on Homeward Nortin Summit Stretch... Just b4 u waved us past.
Both u and ax53 were spitting flames out your exhausts at times -- looked pretty fat although the qualkity is not the best being dark and all! at the time.
Ihavnt had a drive in a while -- hanging. i feel like adrift.
 Share
    • 350/370Z CD005/9 seem to be a good choice, but you'll need to address the diff ratio issue.
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
