hey all, hope you're all well :)
just have some questions re: the first time you rego a car at VicRoads, I understand you have to get a roadworthy certificate first and then take the car down but what's the inspection like when you're down there?
I have a few "cosmetic" issues that i'm not sure if i need to fix or not. Mainly...
- Holes left by rear spoiler on boot AND rear left/right quarter panels. About 22 holes in total. Currently have black gaffa tape on some of the holes :D
- Potentially, a half stripped back to metal, bonnet.
- Aftermarket front bar
Everything is will be completely 100% stock standard, cat, headlights to Halogen, rims, all that crap that has be done at compliance time but i'm not sure whether i have to get the spoiler holes fixed or if i cut the bonnet, whether i can rock up to VicRoads with is half stripped back to the metal? Am i allowed an aftermarket front bar at the first time the car is rego'd?
any help is very much appreciated :P
cheers,
chinny
https://www.sau.com.au/forums/topic/107155-first-rego-at-vicroads-inspection/
cheers,
chinny
If your car passes the RWC then it will not be a problem at the inspection.
When my car was inspected all they checked was the engine number and VIN numbers, took them all of 2 mins.
I doubt they would know if you had an aftermarket frontbar. By having a RWC it tells Vic Roads that your car is road worthy, and they wont think otherwise.
Cheers,
Mark.
This may have no relation to your issues but when i got my first RWC the rear windscreen wiper was removed and covered with tape.. This failed the RWC and i had to have either a replacement glass fitted or which i did plug them up with some for of rubber... I got Foot stops from Clark rubber and silicone them into place..
As Mark stated I was the same the vic roads guy checked the vin and engine number and was on his way to get my plates took about 2 mins as well…
Not sure if this is going to be relevant but just a heads up on it and hope it’s some help..
Matt
so you had issues with the hole left after the wiper was removed? Man i've got like 7 holes on each rear panel and plus the boot holes :D
so if you manage to get a RWC all VicRoads does it check all the numbers are in order?
what if i'm getting a mate at a workshop to do the RWC and he "may" let some things slide, will VicRoads pick up on this? or to them, is a RWC a RWC. What i'm most concerned about is if i haven't got around to respraying the bonnet if i cut it, and it looks mostly black but with bare metal at the end. Structurally it will be fine, but i don't know if they just think it's dodge by the look of it.
thanks for the help guys :)
oh, are they that cluey to check if you've still got Xenon's and stuff like that?
If you have the RWC, they don't care.
All they check is the VIN number and Engine number and Compliance plate.
Most likely it will be some chick that needs help finding the engine number lol.
Don't stress, they don't know much about the actual laws, specifically. So long as you have the RWC, you'll be alright.
have a look at when i joined, and that will give you an idea :P
wanted a R33 initially then saved up a little longer for a R34 (plus parents did want me to get a R33 when i had just turned 19)
Yeah, they just check the engine and vin numbers.
Make sure that the all the engine/VIN numbers on your paperwork is the same, eg roadworthy compliance cert ect ect.. I got sent away by vicroads because I didn't have "RB20" in front of my engine number (even though it isn't part of the engine number) writen on my RWC. So make sure your paperwork is schmick before you go in.
lol had the exact same thing happen to me, but RB25 was missing...
triple check your RWC before you get there mate, last thing you want is to have ur appointment at vic roads, and walk in expecting to drive your baby home registered, and get sent home without rego because of something stupid like the date being written wrong :)
they didnt look at my car at all. popped the hood, compliance plate, engine number etc and thats it. the rest is all inside while he writes up the papers ;)
If you take ur car to the dande vicroads office there are 2 chicks that check the car and they have NFI!!
When I took my hilux surf import in 1 went and got a toyota book coz she couldnt find the engine number.
10 mins later she tells me that my car isent listed in the toyota book. I look at the book and its for locally delivered toyotas!!!! When I told her this she got very embarrassed and just signed off the paper work!!!
hahaha, if i take it to dandy i'm scared my car might be sporting some new "speed holes" down the side as i drive back home :blink:
altho i suppose that driving there with no number plates probably wouldn't turn many heads anyway :(
cool, thanks guys. I know all you guys just had the numbers checked and that's it. I just thought that if there were some very obvious things like a bare metal bonnet, they might start asking some more questions. But seems like a RWC will do the trick and properly filled out forms :woot:
chinny
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
    • Ohhh I see lol To be honest the main reason why I wanted to start modding is because of a business trip to Japan and Indonesia. I saw many cool and modded cars all throughout in these countries, especially Japan. I myself am of Chinese+Japanese nationality and when living in china (never lived in Japan js my dad side lol) I remember staring at these cars pass by with their loud tacky exhausts and insane wide body kits. And when I went back to Japan, I got even more invested even asking people about their cars and why they modded. Most gave similar answers to what you said but funny enough one guy just said that he saw the need for speed movie being filmed once in Tokyo I think near Shibuya Crossing and got inspired to tune and mod. After that I just started to fantasize on owning a car like that. Also tbh I prefer the R32 over the R34 it's just the R34 is more iconic lol (also apparently better aftermarket support than the R32) and my only goal really is just to make the car mine and make it fun to drive. As much as I love my Cayenne it's pretty bland to drive. Sure the interior is nice and pretty, gives you attention yada yada but I've wanted to experience what it is like to have a car that is truly yours. I suppose thats the goal so far. Haha if you find where I'm from, then sure. Ill help you out on your next "financial decision"
    • From what I am discovering, the grey plug is auto signal. If you car is manual it's not relevant to your set up man.
