  • Replies 40
hey mate,
have you got the plastic part on the drivers side arm rest...that surrounds the window switches etc?
sorry nope
anyone else that wants pics of the steering wheel let me know ur email cheers
post-26893-1141128769.jpgpost-26893-1141128828.jpgpost-26893-1141128741.jpgpost-26893-1141128755.jpg
also have engine mounts airbox mounts plugs and buttons dash ask and i will let u know
also have ngk iriduim plugs used for 50km then i decided to change for another brand they cost me $125 bucks asking 50 for em
Hey mate,
Do you have the ignition coil harness? Its the wire that plugs into the ignitior at the back of the engine and runs between the rocker covers and plugs into each of the coil packs?
Cheers
Hey mate,
Cheers
nope sorry mate
Yep happy with the condition of the wheel, I'll take it if you will COD .
i put the steering wheel on ebay cos i didnt think i would sell it so easily i dont know how to stop auctions if it sells it sells if not i will sell it to whoever said they will take it first
You put it on eBay after I (and possibly others) expressed interest, which is totally uncool, but I'll watch and make a last minute bid if it's going real cheap, considering the outrageous amount you want for postage.
I might have offered advice on removing the wheel, but now only after I buy it :O:)
Also, the R32 GTR brakes (Sumitomo) you are offering there are not suitable for 33/34 GTR as we have Brembos that take a larger disc. Also need 5 stud hubs so won't fit R33 GTS and any other 4 stud vehicles. I also don't believe R32 GTR front hubs will fit RWD cars but maybe the hubs off the GTSt you have will be available. Those calipers are no different to R33/34 GTSt/GTt except allow a slightly thicker disc and currently sell for around the $300-400 mark for a pair. Just hope that helps before someone buys them and finds they won't fit straight up.
I might have offered advice on removing the wheel, but now only after I buy it :geek::blush:
lol ok well i ain't never used ebay b4 i dont know who to set the shit up or how much postage will cost but once i have an address then i can work out how much it will cost
shit thats right the r33 hubs are different i better change that oops
is it possible to withdraw a auction on ebay?
How much for jus the front brake calipers, tryin to do 4pot conversion on an s13 with R33 NA rotors
hehe i have had a few interests in the calipers but i wanna sell em with the discs aswell sorry
Were are you located??
perth
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
