hey guys, this is my first post,
does anyone know where i can get a workshop manaul for my R33 gts-t skyline??
it is a 1993
and i canot find anyone that can get me one.
i am in sydney and will drive anywhere to pick it up(longer the better cos i just got the car and want to drive as much as possible) lol
any info would be great
cheers
https://www.sau.com.au/forums/topic/10717-workshop-mauals/
Good timing, WineRed !
W/S manual has just been translated. Here's the link
http://www.jpnz.co.nz
Also try www.power-integration.com for some cool tech stuff and
www.meggala.com
of course ! Download the book "The Sky Is The Limit" as well, It gives factory ECU diagnostics, paint/colour codes and other cool as sh1t..
https://www.sau.com.au/forums/topic/10717-workshop-mauals/#findComment-173283
yeah were all after the workshop manual. the book which gives you detailed information about your engine eletrics etc. the book youd have next to you when doing something under the bonnet, the book that would save us all hundreds of dollars come time to mods the boook that would.....ok
https://www.sau.com.au/forums/topic/10717-workshop-mauals/#findComment-176179
Guy's,,,,I'm sure the manual is copywrited,,,,,So talk in here about Photocopying and Scanning is a NO NO.
Check it out:
www.jpnz.co.nz/xcart/customer/product.php?productid=83&cat=&page=10717
It's $250 NZ,,,,why not just buy it,,,they went to a lot of trouble to translate it.
Neil.
https://www.sau.com.au/forums/topic/10717-workshop-mauals/#findComment-176695
  • 1 month later...
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
