My R32 alternator has died and I'd like to replace it with one from a later skyline or a higher rated new one that will be a straight bolt in.
Mine is Hitachi and has 23100-59S01 LR180-705B on it.
I've been told it's 80 amps.
I can't get the parts to reco it.
Are the R33/34 ones compatable?
What other options?
https://www.sau.com.au/forums/topic/107187-new-alternator/
I don't see why not? If you can, have a look at the mounting on an Rb25, and sus out the wiring harness for it.
The two motors are pretty similar in terms of layout, and don't forget that some R33's had 2L motors in them too...
I doubt they'd be any stronger in terms of amperage output though... what "died" about yours?
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1979234
Interested in this also as running a few thermo's does tax the alt. fairly hard.
I have clocked 204,000km's, I am expecting to replace an alt soon.
I've attached pics of my 1992 R32 ALT.
Once warm my alt drops to 13.3volts under full load high rpm. Always check volts once warm as alt's tend to read higher volts when cold. i.e 13.8-14v.
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1979249
What other options?
The R33 alternators have a larger eyelet connector for the alternator output (B+) compared to the R32's. Simply means you will need to remove the R32 eyelet connector and use a larger one. I think the field wiring is the same although not 100% sure. I believe they share the same rating (80 amps).
Cheers
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1979287
Mine is an 1989, and its the Hitachi 23100-59S01... The one I have stuck to my RB25 has the same part number on it, unless its also an RB20 one.
FAST Lists a 23100-70T16 (newer is 17) for RB25 ?
I don't know what yours is Cubes - I think I did hear somewhere they sometimes came with Mitsu' ones.
I got my old one btw b00ster if you are having trouble sourcing one.. $100 + post. Worked fine on my r32.
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1980046
When I had my HR31 ( RB20DET ), the alternator died and I got a new BOSCH one that fitted straight up and worked a treat. It also had an externally removable voltage regulator ( very handy ).
I'll see if I can find the part number.
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1981858
Its probably only the first section of the number that matters. 23100.
We all seem to have the same first section of the number, just different last.
The 23100 is the parts 'group' - in this case the alternator, and its pretty much universal across all Nissan models. The second set of numbers identifies the specific model/year.
Anyway, alternators are pretty much interchangable across the RB2x range. I put an R33 RB25 alternator in my 89 R32 GTR. It has a 90A output. Pretty much bolted straight in with only slight differences in connector locations - no big deal. I also have an RB20DET alternator in my '87 R31 Silh.
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1981868
I just fitted a brand new alternator tonight and now get a steady 14.2 volts.
I think my old one may not been working properly for a long time
Ever since I've owned the car it's been plagued with flat batteries and hicas light problems as well as the occasional misfiring.
I only spotted the charging problem after fitting a volt meter.
There was never any warning light. I guess the alternator was just making enough charge to keep the light from coming on but not enough to keep the battery from going flat.
I think low battery voltage might even have been the cause of my full throttle lean out.
I know it can make the fuel pump weak.
Can it affect AFM readings or shorten injector pulses enough to lean it out?
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-1994548
Where did you grab the bran new alt. from?
Nissan i remember were stupidly expensive so it must have been an aftermarket matchup?
Nissan quoted $880.
My local auto electrician sourced it from somewhere in Melbourne for $360 plus freight.
It has nissan stamped on it as did the original but no sticker with the nissan part number but apart from that they are identical.
If you want I can try to find out the supplier and their part number but they don't sell to the public.
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-2007336
That would be awesome... IF he parts with it. :P
No doubt it will help out all us SAU'ers at one time or another.
The bearings in mine are beginning to rattle a little, so it won't be long.
I have replaced bearings in alternators before. If you can do without the car for a couple of days it's just a matter of pulling the thing apart and pressing the bearings out. I think it cost less than 30 bucks for a front and rear bearing from cbc (one was an odd ball one so took a day to get). While it's apart replace the brushes which are easily gotten from any decent auto electrician and is usually whats at fault when they aren't charging properly. This was a mazda alternator though.
Total cost of under 60 bucks for what is effectively a new alternator.
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-2013134
Along the lines of what BHDAVE was saying.
Had a Toyota alternator that wasn't charging. Voltage below 12V
I replaced the brushes as they had just worn down so much (van had done 280k km).. cost me $25 to get new brushes in a brush holder. From local auto elec. The brushes are made to wear against the slip rings. You might need to just use ligth sandpaper on the slip rings.. But this worked a treat.
P.S Bearings were fine..
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-2019936
My voltage now stays at 13.8-13-9 with a/c ON and audio OFF. Will drop to 13.6-13.7 with audio ON. That's when the misfiring start again on idle. Planing to change the battery to a bigger capacity (60 or 70). Check Alternator charging & seem ok + healthy. U guys reckon its the battery size?
https://www.sau.com.au/forums/topic/107187-new-alternator/#findComment-2034118
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
