180 sx grey manual sr20 det forged pistons blow off vallve adjustable suspension 3inch exhaust has more extras just cnt think at the moment clean interior body a little rough nothing major car is currently unregistered but will sell with rego if wanted
unregistered $8000
with rego $9000
in sydney
for any questions call 0433300983
Edited by r334u
https://www.sau.com.au/forums/topic/107235-nissan-180sx-sr20det-cheap/
