Was just trial fitting the intercooler today (from JUST JAP) and found a few things I don't have answers for. The original pipe has a little nipple that comes out which is connected to the bleed valve/boost controller. If I take that piece off when I put the new pipe on, where is the boost controller gonna connect to?????.
The blue round things in from of the radiator...........would that be the horn?? if so, why are there two of them??
Lastly, big long pipe that goes over the fan, it has a piece of metal coming out with two holes that seems to connect to the two holes on the engine but when I trial fitted on, they don't seem to match up no matter how hard I try.
If anyone has some detail pic or info of their front mount install for a Series 2 GTST please help me out.
i had the some problem fitting one last week into my sons car o made a bracket that bolts to that flat bit plate and then onto the engine bracket i had to make new brackets for the intercooler as well as the supplied ones didnt quite line up. also the clamps supplied are a bloody tight fit and caused some grief as well my kit wasent from just jap tho it was a geniune hybrid hope the pic helps . btw the horns just undo them and mount them inside the engine bay next to the rad
sorry about posting the same pic twice here is the 2nd pic i ment to post
yep i have a photo where the hole goes but all it shows is the pilot hole for the centre of the holesaw btw the hose from the boost controller i just brought a t piece and connected it the line that comes out of the plenum to the fuel regulater seems to work ok not causing any hassles
Edited by mid life crisis
do you have to relocate the washer bottle at all?
you wouldn't happen to have a picture of the hole from the engine bay would u? so I could get a rough idea where to drill the hole.
mate i didnt even remove the bottle when i drilled the hole the hybrid kit come with picturesand measurments for the hole give me ya email addy and i will pass on the instructions to ya
You'll prob find the cooler was made for an RB20 as the holes will match up no worries on the side of it. You can suvive without this part attached... I have mates who have just broken it off!!
i would rather spend 10 mins making a bracket than just to rip it off and have a lump of broken weld stuck on the pipe let alone taking the chance of tearing a hole in the pipe while ya just rip it off
I got a hybrid kit and it said to trim the fan to make the top pipe fit, i also remade the cooler mounts to make it easier to fit. Then i missed when i drilled the hole and made a bit of a mess, but that should be repaired asap
