DJRIFT - everywhere have the Type-M rotors, just look on the DBA website for their catalogue. When i got my new rotors, most places I rang either had them in stock or could get them in 1 day.
  • 5 months later...
can someone put up some pictures if the difference between the brakes non type m and type m. and did only type m's come with the turbo gauge in the dash?
Type M brakes look nice, and non type M 2 pots do NOT look nice :(
All GTS-t's had the boost guage in the dash, GTS-4's do not have a boost guage, as it is replaced with the torque split.
this front bar means its a type m yeah?
No front bar suggests whether it's a real Type M or not. But generally when people refer to the Type M (Aero option) bar its not that one you uploaded. What you just showed me is a stock front bar.
I'd upload a a pic for you but cbf as I only have 1 arm at the moment. :P
  • 2 months later...
  • 2 years later...
Skyline Brake Setups
MODEL SIZE TYPE R32 T 280mm x 26mm (single pot sumitomo caliper) R32 GTS-T (early) 280mm x 26mm (single pot sumitomo caliper) R32 GTS-T type m 280mm x 30mm (4 pot sumitomo caliper) R32 GTR 296mm x 32mm (4 pot sumitomo caliper) R32 GTR VSPEC 324mm x 30mm (4 pot brembo caliper) R33 GTS-25 280mm x 26mm (single pot sumitomo caliper) R33 GTS-4 280mm x 26mm (single pot sumitomo caliper) R33 GTS-25T 296mm x 30mm (4 pot sumitomo caliper) R33 GTR 324mm x 32mm (4 pot brembo caliper) R33 GTR VSPEC 324mm x 30mm (4 pot brembo caliper) R34 GT 296mm x 30mm (4 pot sumitomo caliper) R34 GTT 310mm x 30mm (4 pot sumitomo caliper) R34 GTR 324mm x 32mm (4 pot brembo caliper) Z32 NA 280mm x 26mm (4 pot sumitomo caliper) Z32 TT 280mm x 30mm (4 pot ali sumitomo caliper) S14, S15 280mm x 30mm (4 pot sumitomo caliper)
wow bringing up an old thread!
for a couple of posts back (and a couple of years back..) heres a pic of my climate control, dont have an analog one though. mine was a 1989 too. im guessing it was a type m? but someone a page back said type m's were only after 1990? can someone confirm this?
also i someone said they come with a different sticker? i dont think ive ever seen a type m sticker on a skyline! anyone got a pic of one? would love to see it!
check out mine here
http://s90.photobucket.com/albums/k250/bou...ling%20skyline/
  • 3 months later...
  • 2 years later...
My VIN is 6U9000HNR32007446 could someone check what version mine is, FAST prog.? I have 4 piston callipers at the front and two piston callipers in the rear not sure if that plays into it.
Edited by Aljo
http://www.skylinesaustralia.com/forums/topic/128496-vins-you-want-fasted/
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
