Noone can tell me why Exedy clutches don't fit series 2 R33s! I've asked 5 people selling all sorts of Exedy clutches, but they don't know. At least everyone is honest and doesn't remove the "R33 92-95" bit.
Some guy on eBay just replied to me with "it will fit". Rather contradictory!
Does anyone know why Exedy clutches all claim they'll fit up to 95 models, but no later?
Are series 2 R33 clutches opposite to the series 1???
And then why is it only Exedy clutches that claim this. (i've seen 6 new clutches advertised, and each seller pastes that text in their description)
Randy,
I am not sure who told you this but i just bought one from the following
http://www.skylinesaustralia.com/forums/in...showtopic=98588
and had it fitted a week ago and the place that did said it went in fine no problems at all.
Edited by leech_
LOL!
And thanks... I've seen 6 different people (3 on SAU, 3 on eBay) post up Exedy button-clutches, and the description always says something along the lines of "R33 up to '95".
It's just weird that they all got this info from SOMEWHERE (suspect Exedy site?) and pasted it up.
hmm that is odd... all i know is my clutch is in and working fine :) maybe monday call exceedy/daiken direct and ask them
LOL!
Me? No. I never said they didn't. I'm just asking why so many other people say they don't.
Check the for sale section for exedy clutches if you want to ridicule someone.
Hey Guys
I would really like to kill this rumour once and for all, the pull style clutch was not introduced into the none GTR range until the R34. All previous GTS-ts, including the R33 GTS25-t, use the same push setup. Also all R32 GTR manufactures until March 1993 also used an interchangeable unit.
If anyone wishes to put this to the test this, with a clutch purchased from us, and I am found to be wrong I will offer a 110% refund. This offer will stand until I have egg on my face :biggrin: If you wish to take the challenge then head over here to look at the clutches available. Unless stated SAU members can take 10% off the price. I can be contact via either PM, email or phone 0400797687.
Regards,
Andrew Sullivan
Kudos Motorsports
That's a bold statement, and i'm willing to believe it because a few people have actually bought and used Exedy clutches in their series 2 R33's.
I have found Greg to be correct also, finding a lot of proof that the series 2's are the pull-type.
Mechanically, I'm not clear as to where the pull or push originates. My clutch slave pushes on the fork, witch then pulls the pressure plate away from the friction plate. It looks to be the same as my mates R32 GTR... so i'm at a loss with that!
It's a bold statement, but I would make it if I wasn't sure I was correct. Following are the clutch engagement setups for both early and late model R33 GTS25-t and the R34 GT-t. Please take note of the position that the bearing carrier is seen. You will notice that in a pull setup (R34) that the bearing carrier is on the rear of the clutch fork while in a push setup its on then engine side. Also note that there is no difference between the R33 setups.
The offer still stands if anyone wants to try and prove me wrong.
So you're saying that they are both push-type.. both series1 and 2?
In which case I really don't understand why a lot of people advertise Exedy clutches for R32 and R33 series 1 when they infact fit series 2.
=-o
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
