Noone can tell me why Exedy clutches don't fit series 2 R33s! I've asked 5 people selling all sorts of Exedy clutches, but they don't know. At least everyone is honest and doesn't remove the "R33 92-95" bit.
Some guy on eBay just replied to me with "it will fit". Rather contradictory!
Does anyone know why Exedy clutches all claim they'll fit up to 95 models, but no later?
Are series 2 R33 clutches opposite to the series 1???
And then why is it only Exedy clutches that claim this. (i've seen 6 new clutches advertised, and each seller pastes that text in their description)
Randy,
I am not sure who told you this but i just bought one from the following
http://www.skylinesaustralia.com/forums/in...showtopic=98588
and had it fitted a week ago and the place that did said it went in fine no problems at all.
Edited by leech_
LOL!
And thanks... I've seen 6 different people (3 on SAU, 3 on eBay) post up Exedy button-clutches, and the description always says something along the lines of "R33 up to '95".
It's just weird that they all got this info from SOMEWHERE (suspect Exedy site?) and pasted it up.
hmm that is odd... all i know is my clutch is in and working fine :) maybe monday call exceedy/daiken direct and ask them
LOL!
Me? No. I never said they didn't. I'm just asking why so many other people say they don't.
Check the for sale section for exedy clutches if you want to ridicule someone.
Hey Guys
I would really like to kill this rumour once and for all, the pull style clutch was not introduced into the none GTR range until the R34. All previous GTS-ts, including the R33 GTS25-t, use the same push setup. Also all R32 GTR manufactures until March 1993 also used an interchangeable unit.
If anyone wishes to put this to the test this, with a clutch purchased from us, and I am found to be wrong I will offer a 110% refund. This offer will stand until I have egg on my face :biggrin: If you wish to take the challenge then head over here to look at the clutches available. Unless stated SAU members can take 10% off the price. I can be contact via either PM, email or phone 0400797687.
Regards,
Andrew Sullivan
Kudos Motorsports
That's a bold statement, and i'm willing to believe it because a few people have actually bought and used Exedy clutches in their series 2 R33's.
I have found Greg to be correct also, finding a lot of proof that the series 2's are the pull-type.
Mechanically, I'm not clear as to where the pull or push originates. My clutch slave pushes on the fork, witch then pulls the pressure plate away from the friction plate. It looks to be the same as my mates R32 GTR... so i'm at a loss with that!
It's a bold statement, but I would make it if I wasn't sure I was correct. Following are the clutch engagement setups for both early and late model R33 GTS25-t and the R34 GT-t. Please take note of the position that the bearing carrier is seen. You will notice that in a pull setup (R34) that the bearing carrier is on the rear of the clutch fork while in a push setup its on then engine side. Also note that there is no difference between the R33 setups.
The offer still stands if anyone wants to try and prove me wrong.
So you're saying that they are both push-type.. both series1 and 2?
In which case I really don't understand why a lot of people advertise Exedy clutches for R32 and R33 series 1 when they infact fit series 2.
=-o
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
