I've heard a few stories of putting a cup of ATF in your fuel working a treat. anybody know of any draw backs other than the obvious ie pinging etc? apparently it does a better job than using injector cleaner but.. that's also made for the job... I have a ultrasonic bath I can gain access to, but achieving the same result just by driving the car seems alot more appealing than having it off the road and apart for a few days.
Jeremy
https://www.sau.com.au/forums/topic/107289-using-atf-as-a-fuelinjector-cleaner/
You remove the injectors and take it to a specialist who cleans them ultrasonically.
That by far is the best way, but it costs about 20 bux an injector.
But the Techron is probably the best stuff you can get in a bottle besides removing the injectors.
Edited by Busky2k
I got quoted $300 for ultrasonic cleaning by driftking in brissie. $700 for a service made me fairly sure they were rip off merchants. I'm going to pull an injector out today and have a look at it under a microscope today, see if i can see anything. I think I'll just bite the bullet and pull the lot out and ultrasonic bath em. Thanks for the replies guys, putting oil through my system didn't really seem like the best thing to do...
Out of interest, what is the price of hiflowing injectors? What sort of kw are they good for? Is it worth it or is it better just to buy newies?
I wouldnt put them into an ultra sonic bath that you clean your jewelry. Thats how you ruin them cos it can damage the solenoids.
The professionals have them hooked up to a rail and pulse the injectors with cleaning fluid whilst the *nozzles* are in the ultra sonic bath, not the whole unit!
Hey Busky
Thanks for the advice, yeah I've been doing a fair bit of researching on the net today (god i love work on the weekends), and as always, I have found that it's not as simple as it first seems.
The U/S bath that I have access to is actually in the lab here at work, but yeah essentially I think it's the same jobbie as the jewellery cleaners. why dont they have an injector rail here dammit! lol.
I'm pretty much sure now that I'm going to get the injectors hiflowed now anyway. I did take injector 1 out today and found the nozzle to be completely spotless under the microscope. The inlet filter had a bit of junk on it, so I think I'll just run some of that techron gear through it, if I do anything, before hiflowing them.
To clean the filters most people 'backflush' the injector but its pretty hard to do with the injector off the car cos you need to open the injector somehow. (And dont try it with a battery!)
If you're gonna get them high flowed, just leave em alone and let the guy do the work haha.
Btw Techron is good on removing deposits on the backside of the intake valves aswell.
yeah the way I figure it, it cant hurt to put a bottle through anyway. I just have to wait till i'm in the vicinity of a place that stocks it. I luuuuurve living in the sticks <_<
I kinda broke one of the little legs off the pintle cap too :P from what I can find they're mainly to stop residue build up, so it should be fine in the interim.
you would probably be better of getting s15 480cc ones or nismo 550cs instead of hiflowing
you will need an aftermarket ecu to support those.
i am not sure how hiflow injectors will work with the stock ecu
as i think the latency would be the same for idle control ? i have no idea on that matter sorry
yeah as you can see i'm still learning too. my laymans understanding suggests that the stock ecu would not have the ability to tune to different flow injectors, regardless if they're flowed stockies or other.
oil in your fuel???
i heard if you get sand and pour it in your intake, while someone is reving to 7000, ports your head. good for around 100rwkw
holy crap really!!! I'm so going to do that tonight!!!
Idiot :happy:
I'd appreciate if you didn't turn my legitimate thread into just another spam thread, thanks. Take your "phat" arse to boostcruising if that's your thing. There is evidence that it actually works, mechanics have been doing it for years.
Jeremy.
Edited by jezzerrr
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
