I've heard a few stories of putting a cup of ATF in your fuel working a treat. anybody know of any draw backs other than the obvious ie pinging etc? apparently it does a better job than using injector cleaner but.. that's also made for the job... I have a ultrasonic bath I can gain access to, but achieving the same result just by driving the car seems alot more appealing than having it off the road and apart for a few days.
Jeremy
https://www.sau.com.au/forums/topic/107289-using-atf-as-a-fuelinjector-cleaner/
You remove the injectors and take it to a specialist who cleans them ultrasonically.
That by far is the best way, but it costs about 20 bux an injector.
But the Techron is probably the best stuff you can get in a bottle besides removing the injectors.
Edited by Busky2k
I got quoted $300 for ultrasonic cleaning by driftking in brissie. $700 for a service made me fairly sure they were rip off merchants. I'm going to pull an injector out today and have a look at it under a microscope today, see if i can see anything. I think I'll just bite the bullet and pull the lot out and ultrasonic bath em. Thanks for the replies guys, putting oil through my system didn't really seem like the best thing to do...
Out of interest, what is the price of hiflowing injectors? What sort of kw are they good for? Is it worth it or is it better just to buy newies?
I wouldnt put them into an ultra sonic bath that you clean your jewelry. Thats how you ruin them cos it can damage the solenoids.
The professionals have them hooked up to a rail and pulse the injectors with cleaning fluid whilst the *nozzles* are in the ultra sonic bath, not the whole unit!
Hey Busky
Thanks for the advice, yeah I've been doing a fair bit of researching on the net today (god i love work on the weekends), and as always, I have found that it's not as simple as it first seems.
The U/S bath that I have access to is actually in the lab here at work, but yeah essentially I think it's the same jobbie as the jewellery cleaners. why dont they have an injector rail here dammit! lol.
I'm pretty much sure now that I'm going to get the injectors hiflowed now anyway. I did take injector 1 out today and found the nozzle to be completely spotless under the microscope. The inlet filter had a bit of junk on it, so I think I'll just run some of that techron gear through it, if I do anything, before hiflowing them.
To clean the filters most people 'backflush' the injector but its pretty hard to do with the injector off the car cos you need to open the injector somehow. (And dont try it with a battery!)
If you're gonna get them high flowed, just leave em alone and let the guy do the work haha.
Btw Techron is good on removing deposits on the backside of the intake valves aswell.
yeah the way I figure it, it cant hurt to put a bottle through anyway. I just have to wait till i'm in the vicinity of a place that stocks it. I luuuuurve living in the sticks <_<
I kinda broke one of the little legs off the pintle cap too :P from what I can find they're mainly to stop residue build up, so it should be fine in the interim.
you would probably be better of getting s15 480cc ones or nismo 550cs instead of hiflowing
you will need an aftermarket ecu to support those.
i am not sure how hiflow injectors will work with the stock ecu
as i think the latency would be the same for idle control ? i have no idea on that matter sorry
yeah as you can see i'm still learning too. my laymans understanding suggests that the stock ecu would not have the ability to tune to different flow injectors, regardless if they're flowed stockies or other.
oil in your fuel???
i heard if you get sand and pour it in your intake, while someone is reving to 7000, ports your head. good for around 100rwkw
holy crap really!!! I'm so going to do that tonight!!!
Idiot :happy:
I'd appreciate if you didn't turn my legitimate thread into just another spam thread, thanks. Take your "phat" arse to boostcruising if that's your thing. There is evidence that it actually works, mechanics have been doing it for years.
Jeremy.
Edited by jezzerrr
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
