post-26887-1140863275.jpgpost-26887-1140863379.jpgpost-26887-1140863666.jpgpost-26887-1140863772.jpg
post-26887-1140863888.jpgpost-26887-1140863982.jpgpost-26887-1140864110.jpgpost-26887-1140864228.jpg
post-26887-1140864338.jpgpost-26887-1140864553.jpgpost-26887-1140864759.jpgpost-26887-1140864903.jpg
- 1990 R32 GTR
- Paint is an R34 GTR Midnight Purple III color (color code LX0),
Midnight Purple / Midnight Blue with Gold pearl Chameleon paint and is in showroom condition.
Its amazing that this color came out on the R34 GTR's as a factory color.
- 90,000 kms
- New K&N air filters
- New 444cc injectors
- Sway bar
- New exedy clutch
- New flywheel
- HKS 3" cat back exhaust
- Ohlins Adjustable suspension
- New suspension bushes
- Just been serviced with new sparkies, gearbox oil, engine oil, oil filter.
- 17” rims with 90% Bridgestone tread
- Tinted windows
- Interior immaculate
- Apexi turbo timer
- Pioneer CD unit
- Always garaged
- Comes with RWC and plenty of rego
Price $27,000 ono
If anyone is interested you can contact me on 0422 649 197
I took pictures on a sunny day and on a cloudy day to give you guys an idea of what chameleon paint is all about.
Edited by gtr_lx0
https://www.sau.com.au/forums/topic/107294-r32-gtr-midnight-purple-3-with-pics/
Best factory colour EVER. I came very close to repainting my R32 this colour last year, but decided to spend it on performance mods instead.
Top stuff.
ay i found a pic of an r34 gtr with midnight purple III paint.
as u can see.....i'm a big fan!!
ay whats the reason for selln it?
I've decided to sell it because i'm planning to transfer overseas on a working visa so i'm basically tieing up a few loose ends before i go.
Thats a nice looking Skyline mate,
Good luck with the sale
thanks mate.....new price everyone,
$25,000
this paint job is very rare and i spent alot on it so this is a good price guys. This is a great example of a clean and smooth gtr. I've put alot into it so who ever gets this car next will be extremely happy with the work that has gone into keeping it a very reliable gtr.
Edited by gtr_lx0
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
