I now have all the goodies that I need to attempt to convert my C210 from auto to manual (found a good box from a 240K) - except a crossmember... Does anyone know if I can use the existing one, or will I need to grab one from a manual car.
Cheers
https://www.sau.com.au/forums/topic/107301-c210-auto-to-manual/
What a travesty!
1. Tried to mount flywheel to a washer that mounts the the automatic transmission only.
2. Clutch kit did not come with bolts to mount pressure plate to flywheel.
3. Slave cylinder did not come with mounting bolts.
4. Ran out of light and butchered the wiring trying to hook up the reverse lights. Now there are no reverse lights and instead of brake lights I get a door warning light come on instead when I hit the brakes WTF!
5. 2nd gear syncro is not in the condition that the box was advertised in... Ker-unch!
Ah well... learning curve and all. Seriously if anyone does know what color wire and where to connect the reverse lights to the unit in the box I'd be much obliged.
Cheers!
LOL Don't worry man, we mounted the flywheel to the auto spacer thing too... was a real bitch!! Then we had to take it off. hahaha
Don't you have a service manual? Check the wiring diagram and it'd be easy as. Or just play guess and check...
I can scan in the wiring diagram if you need it, just ask.
Sounds like you went pretty trouble-free!! On my car, the new clutch wasn't the same as the old one, so had to figure out what it was... Turns out most Nissan clutches are ALMOST the same. Went with a bit of a educated guess at 280ZX and we got it right. Plenty of other problems too - the worst bit IMO was the bloody pedals! Hope you had fun :)
Lachlan
What a travesty!
Cheers!
Turns out most of my wiring confusion stemmed from a blown fuse! Ideal timing - I thought I must have mashed a wire or switch for sure...
I got my hands on original factory manual at a fairly horrific cost and will trace the wiring for the reverse lights tomorrow.
Other than a leak in the clutch line its nearly all done.
Not sure what I will do about the nasty 2nd gear syncro in the end... do I get the box rebuilt (expensive) or search for another 2nd hand box and hope its OK (wishful thinking)?
Oh yeah! The gearlever for the 240K and the C210 are similar, but not the same... It fits until you try and put the centre consol back in. Son of bitch! I'll laugh about it tomorrow.
Drew
The 240K lever is bent like an L. Mount it one way and you cant get 1st, 3rd and 5th cause it makes contact with the console, mount it the other way and 2nd, 4th and reverse are out the door. I am currently driving with the console sitting on the back seat. I am assuming the C210 gear lever must be fairly straight, as the manual C210s that I have seen have an identical centre console to mine.
Should I get the syncros from Nissan, or is their a better source?
Interestingly mounting the pedals wasn't too bad, I kept the pedal box and hung the clutch and smaller brake pedal off the ends of the fulcrum... Very handy tip!
Yeah did that too.. was just a bastard for some reason. heh! Anyway, the 240K gear lever isn't like an L... it's straight! Sounds like you got a lever from something else... Z cars have a kink in them, like ... (excuse my poor ascii skillz)
Dunno.. I might have a spare 240K one soon though, will let you know.
I dont know about all the synchros and stuff, best bet is to find a good gearbox place and ask them :| Easier said than done
That's just bizarre, the lever definitely is bent like you described... must have come off another car! Found a straight one at Z spares and had a dog of a time mounting it properly, really hard to push the pin through in neutral, but the pin goes in easy enough when its in 1st... baffling. Thanks for looking though.
Ill let you know how I go finding syncros. Also will post a few pics of the car after it finally gets lowered on Tuesday.
Drew
For reference, here's a picture I took when I did mine, showing the C110 stick (straight) and the S30 stick (bent).
Are you sure you've got a C210 box? Not that it really matters, just the ratios may be different.
Interesting,
A c210 manual 5-speed is available to me, and i was wondering if the ratios in it are the same as those found the c110 5-speed? - sort of related...:dry:
As far as I know my box is out of a 240K, and the advantages of this are 1st and 2nd are not as tall as the Z boxes, and the syncros are made of bronze, making them a hell of a lot cheaper to repair than the Z boxes... but I am not sure of the differences (if any) between the 240k and c210 boxes. Anyone? Anyone?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
