I now have all the goodies that I need to attempt to convert my C210 from auto to manual (found a good box from a 240K) - except a crossmember... Does anyone know if I can use the existing one, or will I need to grab one from a manual car.
Cheers
https://www.sau.com.au/forums/topic/107301-c210-auto-to-manual/
What a travesty!
1. Tried to mount flywheel to a washer that mounts the the automatic transmission only.
2. Clutch kit did not come with bolts to mount pressure plate to flywheel.
3. Slave cylinder did not come with mounting bolts.
4. Ran out of light and butchered the wiring trying to hook up the reverse lights. Now there are no reverse lights and instead of brake lights I get a door warning light come on instead when I hit the brakes WTF!
5. 2nd gear syncro is not in the condition that the box was advertised in... Ker-unch!
Ah well... learning curve and all. Seriously if anyone does know what color wire and where to connect the reverse lights to the unit in the box I'd be much obliged.
Cheers!
LOL Don't worry man, we mounted the flywheel to the auto spacer thing too... was a real bitch!! Then we had to take it off. hahaha
Don't you have a service manual? Check the wiring diagram and it'd be easy as. Or just play guess and check...
I can scan in the wiring diagram if you need it, just ask.
Sounds like you went pretty trouble-free!! On my car, the new clutch wasn't the same as the old one, so had to figure out what it was... Turns out most Nissan clutches are ALMOST the same. Went with a bit of a educated guess at 280ZX and we got it right. Plenty of other problems too - the worst bit IMO was the bloody pedals! Hope you had fun :)
Lachlan
  coupe72001 said:
What a travesty!
Cheers!
Turns out most of my wiring confusion stemmed from a blown fuse! Ideal timing - I thought I must have mashed a wire or switch for sure...
I got my hands on original factory manual at a fairly horrific cost and will trace the wiring for the reverse lights tomorrow.
Other than a leak in the clutch line its nearly all done.
Not sure what I will do about the nasty 2nd gear syncro in the end... do I get the box rebuilt (expensive) or search for another 2nd hand box and hope its OK (wishful thinking)?
Oh yeah! The gearlever for the 240K and the C210 are similar, but not the same... It fits until you try and put the centre consol back in. Son of bitch! I'll laugh about it tomorrow.
Drew
The 240K lever is bent like an L. Mount it one way and you cant get 1st, 3rd and 5th cause it makes contact with the console, mount it the other way and 2nd, 4th and reverse are out the door. I am currently driving with the console sitting on the back seat. I am assuming the C210 gear lever must be fairly straight, as the manual C210s that I have seen have an identical centre console to mine.
Should I get the syncros from Nissan, or is their a better source?
Interestingly mounting the pedals wasn't too bad, I kept the pedal box and hung the clutch and smaller brake pedal off the ends of the fulcrum... Very handy tip!
Yeah did that too.. was just a bastard for some reason. heh! Anyway, the 240K gear lever isn't like an L... it's straight! Sounds like you got a lever from something else... Z cars have a kink in them, like ... (excuse my poor ascii skillz)
Dunno.. I might have a spare 240K one soon though, will let you know.
I dont know about all the synchros and stuff, best bet is to find a good gearbox place and ask them :| Easier said than done
That's just bizarre, the lever definitely is bent like you described... must have come off another car! Found a straight one at Z spares and had a dog of a time mounting it properly, really hard to push the pin through in neutral, but the pin goes in easy enough when its in 1st... baffling. Thanks for looking though.
Ill let you know how I go finding syncros. Also will post a few pics of the car after it finally gets lowered on Tuesday.
Drew
  Alfadog said:
For reference, here's a picture I took when I did mine, showing the C110 stick (straight) and the S30 stick (bent).
Are you sure you've got a C210 box? Not that it really matters, just the ratios may be different.
Interesting,
A c210 manual 5-speed is available to me, and i was wondering if the ratios in it are the same as those found the c110 5-speed? - sort of related...:dry:
As far as I know my box is out of a 240K, and the advantages of this are 1st and 2nd are not as tall as the Z boxes, and the syncros are made of bronze, making them a hell of a lot cheaper to repair than the Z boxes... but I am not sure of the differences (if any) between the 240k and c210 boxes. Anyone? Anyone?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
