  • 1 month later...
just jump onto the tacho wire at the back of the dash cluster. use a test light to find out which 1 it is. it will be a thicker wire. just start the car and try all the wires with a test light. the tacho wire will flash (very fast) and if u rev it it will get brighter ( cause it is flashing faster)
i might add a note when checking for tacho pulse it is important to use a led test light as these do not draw any current in which could harm igniter or ecu if you use a lighht bulb test light it could over load the circuitry causing failure
just my two cents
using a normal test light or an led test light won't make much difference. but it depends on that u are testing. testing the tacho wire between the ecu and the tacho will have less affect than testing between the engine and the ecu if something went wrong. and using a normal light would draw similar current to a monster tacho.
i used a normal test light on my last car when i was hooking a shift light up (still used factory tacho though. no point putting in a 5 inch tacho when there is already 1 there) and there was no problem.
fair enough to use 1 if your car doesn't have a tacho or the factory 1 is dead.
  • 1 month later...
just to help anyone out who is reading through, the tacho wire on the r33 ecu is a yellow with a blue stripe wire. when the ecu is still bolted in, it is in the top row (right hand side when the ecu is vertical) and 4th pin up from the centre bolt. its not the 4th wire, as some cars have different wiring configurations due to different options, but the 4th hole in the plug.
  • 5 months later...
  • 3 weeks later...
i have connected my rpm signal to the ecu output which does lead to the back of the cluster, but i dont know if anyone has had the same problem where the tacho doesnt read right as the output from the ecu is a 5v square wave and the autometer tacho needs 12v square wave. is there a way to fix this without buying extra modules to convert the signals.
  • 1 month later...
Yeah I have the same problem.. no idea how to solve it though.. hope someone has an answer..
  • 2 years later...
that advice is spot on.
thanks mate, helped me to put my digital tacho in by myself.
don't seem to have the same 5v versus 12v problems as everyone else though.
it's the $99 dollar one from justjap, inbuilt shift light too :)
  • 1 year later...
This was one of the only threads I could find that helped with installing my eboost2 so I could use the rpm function. I didnt have the instructions which are on there website, but what I came across was when connected up, the main tacho stopped working. after putting a 2k ohm resistor inline to the eboost they both now work correct.
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
