Hi. Just like my r33 auto.. the auto trany in my stagea seems to have a habbit of changing into 2nd very early when in normal auto mode and the opposite when in tripronic mode ( hangs on to 1st gear for too long ).Its only a minor gripe and triptronic mode is a lot of fun and I have found that short shifting helps..but it would be nice to be able to reprogram the trany to shift at more appropriate points..any ideas??
Scott.
https://www.sau.com.au/forums/topic/107344-stagea-auto-transmision-changes/
donno if that will help you but try reseting the computer - disconnect the battery and put a brick on the break pedal overnight (will draw all the power from mem chip) that should work only if the stagea remembers driving patterns
I quite like the responsiveness of the A/T in my stagea. in tiptronic/manual mode it's not going to change gears by itself at all so I'm not sure what you're trying to say there.
resetting the ecu only takes 30 sec,pull the fuses out and wait,then re-install.
as for changing the preset points,you could try chipping the A/T ecu,but unless you know exactly what you're doing,you're more likely to make it worse to drive than better. there are several factors that determine when the box will change gears,playing with them singly may produce the results you desire,but may also make things worse. tinker if you must.
nissan generally get that sort of thing right though.
Justin...
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
