Item: custom subzero plenum to suit gtr skyline rb26dett, perfect upgtade for high power gtr or vl runing 30ltr and gtr head, all alloy made, suit 100mm trottle body or Q45 90mm
Item Condition: Excellent as new hardly used, just dyno work.
Reason for Selling: No longer needed
Price and Payment Conditions:$580. Pick up, direct deposit.
Extra Info:as new, done 50kms comes with speed flow fittings.
Contact Details:PM or post here.
Edited by MR33
https://www.sau.com.au/forums/topic/107365-custom-pleunm-gtr/
  MR33 said:
if u chasing big power its good, i have one on my car and i make 810hp at 4 wheels
Sorry to be a pain as i am interested. Will it bolt straight on? Iv got 304rwkw and am wondering if it will make any difference and specificaly what are the performance advantages (why is it better than standard)
CHEERS
CHEERS
Um! Will it?
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
