Gtr-road Or Track-may Swap For 180sx+cash
Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/ You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70 -
You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
@johnnysr22 did you end up installing the little screen thingy and did it work ?>
There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in. Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work. If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
