Thats a nice and clean 4door abobob :laugh: . Ill be getting a yellow 2 door soon if everything goes well, one with same factory kit, eyelids etc. But the one im after comes with the huge ugly spoiler ;) wtf were they thinkin when they designed it haha its gotta go :D .
Somehow I missed all these extra replies.
_8OO5TED_ - 255rwkw at 0.9 bar
GCG highflow turbo
Nismo 480cc injectors
Tomei 260 degree Poncams
Wiseco Forged pistons (8.75:1CR)
Pro Engines oil pump drive collar
Blitz LM FMIC
CES and Fujitsubo exhaust
Nismo panel filter
MV Automatics valvebody upgrade and rebuilt trans to handle 300+rwkw
Bilstein Shocks
Kings Springs
Powerplay ROM Tune
Apexi AVC-R
Dual core copper radiator
Oil cooler
97r33gtst-typeM - they are still not common here in Australia.
silver gts-t - yeah something like those would be nice.
I'm not abo or arabic, I'm 6th generation aussie from 50/50 Irish and English blood. I will keep the nick so as to add to my online allure. :P
POOMBAH - Yeah it is good. Sometimes I wish I could stretch it about 3-4cm down without wrecking the lines.
Maxx - I've never seen series two in the flesh. In some pics it looks great, in others awful.
JUNR34 - The factory eyelids are the way to go. Better than the aftermarket ones unless you have a black car with CF bonnet and CF eyelids like E-Lu-Shun.
That wing you are referring to is the Altia wing and is ugly as. When you take off the side sections they leave dirty great big holes in the rear quarters too.
  • 6 months later...
GCG highflow turbo
Blitz LM FMIC
Nismo panel filter
Bilstein Shocks
Kings Springs
Powerplay ROM Tune
Apexi AVC-R
Oil cooler
dam that carbon bonnet looks good. im after the same nismo style one but cant find one anywhere, and the eyelids in cf too.
ohh and abobob ur 34 looks great.
Troy that story does not get published on the forums.
The mechanic who took it for the pink slip test drive bottomed it out but I don't. I raised the cooler while the car was out of action so it went up an inch and the car came down an inch.
I modified the front bar a little with help from 666dan.
My rims are cheap and nasty but I would love some nice black 18's. (maybe like these ones http://www.skylinesaustralia.com/forums/in...owtopic=106464) or better still some nismo lmgt4 or whatever they are called - I'm not very good with the names. Just don't have the cash atm.
abobob
do you have any close up pics of the lower lip of the front bar(where it says SKYLINE)? did you fill the holes after you cut that section out?
thanks
Most of my paint job is less than 2 years old. That helps. Also I give it a full wax twice a year and spot polish it during the year.
I don't think I've got any pics of that bit sorry but no I didn't full the holes. I've been meaning to but haven't got around to it and nobody notices it unless they go looking for it.
i have to say at first i didnt like 4 door skylines but i was pondering about it the other day and i think im almost converted.
talk about practical! you get the best of both worlds
but i really dont like 4door r33's whats the deal with there rear lights, some of them look so unco
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
