What are you going to do regarding the engine harness? The question is, IS the stagea plug the same as a R34 GTT?
If need be, use a R34 GTT harness
There is one for sale at the moment for $400
When my 2 Stagea's get here in approx 3 weeks, I will be able to compare my S1 and S2 side by side, and also have my R33 GTST to compare with if need be.
Also my importer mate has 2-off S2 Stagea Neo engines with "manual boxes" attached coming this week, so I will be comparing them aswell.
  • 3 months later...
  • Replies 52
i Spoke to John at UAS yesterday, he can supply, fit and dyno tune a power fc onto a S2 rs four s stagea for $2200
Bozidar, who i work with for saikoogarage.com can do an installed an tuned pfc for 1800. You'd probably get change.
And he can sure tune em - he built a 180sx w/ SR20DET up that does 11.3 quarters.
the next thing of course is which specific model FC to get? as there are a few different ones available?
if anyone has a specific part number/model number would be a good thing to go on.
would make life easier when searching the net or shops for prices etc.
Thats really does suck, because i do believe well in my case anyway that it is a waste of time and money going manual, i would just be better off buying a 260rs which im not going to do as of yet anyway, or just going back to an S13/14/15 manual standard from factory.
If you want manual buy a car manual from factory, conversions are always a pain in the arse.... and that is from experience
but for the guys who bought their stags a while back when manuals were up around 30k self import and autos were 15 to 20 grand still a cheaper proposition to go manual via a conversion and also with the ratios of manuals to autos it far easier to find a car with everything you want and the colour you want for a good price than a similar manual
my 2c
I fully understand what you are saying, and i give props to anyone who has done or is going to convert to manual.
Basically my point that i was trying to make was its a shame they dont make auto pfc, as i dont intend on going manual, well in the short term anyway.
And im sure a lot less people would go manual if they new they could get pfc for auto.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
