Hi All,
Just a heads up for everyone who is doing, or going to do mods on their cars. This might effect the RB25/26/30 combos we'd all like to do, as well as RB into 200SX, etc, etc....
But that's just the tip of the iceberg, fuel systems, exhausts, chassis strengthening, the list goes on.
Have a read & bear in mind that it's not law yet, it's just a draft (from what I've been told). But it is an indication of things to come......
PDF files at the bottom of the page.
http://www.dotars.gov.au/transreg/vsb/vsb_ncop.aspx
EDIT: While I'm not completly opposed to rioting or blocking the pollies in parliament house with our cars..... You can express your outrage to the following people:
"Further comments on the NCOP may be directed to the following email addresses.
[email protected]
[email protected] South Wales
[email protected] Capital Territory
[email protected] Australia
[email protected] Territory
[email protected]
[email protected]
Edited by yug_r34
https://www.sau.com.au/forums/topic/107441-new-government-safety-standards/
http://www.dotars.gov.au/transreg/vsb/PDF/...es_3Feb2006.pdf
2.1 Choice of replacement engine - The power and/or torque of the replacement engine should not exceed the capaicty of the vehicle driveline.
There goes your RB30DET with an RB20DET gearbox.
2.2 Replacement components such as camshafts... engine management systems, exhaust systems, etc. are not permitted unless it can be demonstrated that the ehicle continues to meet the appropriate gaseous and noise emmission standards.
Note: the fitting of NOS injection systems is not permitted.
There goes PFC, most exhausts, cams, probably cam gears, unless emmissions tests are still passable. That also seems to say that removing your nos bottle is not longer acceptable.
very worrying, anyone wanna attempt a simplified version, i wanna put a 26/30 in my gts-t or something of the sort how will this affect me? can it still be done if (when) this is passed? im so gonna protest if it does, australia is becoming the retirement village of the world. fark florida off come to australia.
edit: ps. this is quite irritating, wats wrong with a bit of good clean modified fun, honk if your as upset about this as i am, although alot of it is nothing new, the cams etc. dribble is greatly troubleing
Edited by Style32
If worse comes to worse We could always gather our cars & park them around Parliament house, starve 'em until they get rid of all the poorly researched bandaid laws concerning modified & imported cars :D:)
Is this still in the draft stages ie: just a proposal
or is there actual legislation being put through on this? can anyone comment on this?
I am planning on buying an r34 GTT in a year's 1/2 time, if those laws are put in place may as well just save up a few more years & buy a GTR :
If you ask me the government should tackle the big issues: huge carbon fibre wings on excels
Edited by POOMBAH
Just added the relevant e-mail addresses to vent our collective anger. See topic starter or below:
[email protected]
[email protected] Australian Capital Territory
[email protected]
[email protected]
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
