Revs Drop At 5000 To 4700 At 3rd Gear And Then Slowly Struggles To Climb. What Could Be The Problem?
Hi guys,
Can someone tell me what the problem could be?
When I rip the 34gtt, 1st and 2nd are sweet but as i put it into 3rd and once it reaches 5000 the revs drop down to 4700 and then it lags and struggles to climb back up and once it passes 5000 its normal again...
I am losing power at this point and would like to know where the problem lies? can someone please help me?
Any advice would be greatly appreciated, thank you.
Clutch dude... Between that rev range you're pulling the most amount of torque therefore a good chance it may be slipping. It's a good indication that your clutch is on the way out.
Yeah have to agree clutch is a strong chance. Not really sure why it would then struggle to accelerate once it's bitten though, bit strange. Could be just that it drops just below the rev point that the cam is meant to switch between the low & high advance setting. ECU may be getting confused since ur on full throttle & the revs suddenly drop.
^^ nope not neccessarly..
it can start to slip from 3rd and onwards, or even in 2nd.. After a while, if you dont replace your clutch, it will start slipping from 1st, and u wont be able to get past 20ks.. ahhah from experience..
I remember drivin on the last day to the workshop, with the clutch slippin in 1st, i could not go faster than 20ks..
Might not even be your clutch.. maybe a more knowledgable person, could suggest something else..
Correct me if im wrong but if a clutch was slipping, u would not be goin from 5k DOWN to 4700rpm... It would be the other way round cause ur affectively reducing load on the engine.... Maybe some sort of engine management issue for a certain load condition and rev range. U'd have to play around with diff Throttle positions once u reach that condition n see if it makes a diff, id imagine these ECU's get their load readings off the TPS.
I personally doubt that it's something electronic. How does a manual car suddenly drop 300 rpm without dropping speed at the same time? They're not like an automatic which will vary revs according to how much throttle is applied.... unless the clutch is slipping. If the revs are higher torque has less of a role to accelerate the car. I'd say chances are he's slipping at middle revs at peak torque. When power takes over the clutch bites again
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
    • All of them are missing. You do not get much done with just AND, OR and NOT unfortunately. Ecumaster for example has a text based editor with at least 60+ math and logic instructions.
