Amadeo Posted February 27, 2006 Share Posted February 27, 2006 Hi guys, Can someone tell me what the problem could be? When I rip the 34gtt, 1st and 2nd are sweet but as i put it into 3rd and once it reaches 5000 the revs drop down to 4700 and then it lags and struggles to climb back up and once it passes 5000 its normal again... I am losing power at this point and would like to know where the problem lies? can someone please help me? Any advice would be greatly appreciated, thank you. Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/ Share on other sites More sharing options...
Savage Bliss Posted February 27, 2006 Share Posted February 27, 2006 Clutch dude... Between that rev range you're pulling the most amount of torque therefore a good chance it may be slipping. It's a good indication that your clutch is on the way out. Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1983131 Share on other sites More sharing options...
J_Red33 Posted February 27, 2006 Share Posted February 27, 2006 Yeah have to agree clutch is a strong chance. Not really sure why it would then struggle to accelerate once it's bitten though, bit strange. Could be just that it drops just below the rev point that the cam is meant to switch between the low & high advance setting. ECU may be getting confused since ur on full throttle & the revs suddenly drop. Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1983374 Share on other sites More sharing options...
Amadeo Posted March 2, 2006 Author Share Posted March 2, 2006 I thought that for a clutch to be slipping it would need to slip from first gear? Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1990095 Share on other sites More sharing options...
siddr20 Posted March 2, 2006 Share Posted March 2, 2006 ^^ nope not neccessarly.. it can start to slip from 3rd and onwards, or even in 2nd.. After a while, if you dont replace your clutch, it will start slipping from 1st, and u wont be able to get past 20ks.. ahhah from experience.. I remember drivin on the last day to the workshop, with the clutch slippin in 1st, i could not go faster than 20ks.. Might not even be your clutch.. maybe a more knowledgable person, could suggest something else.. Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1990135 Share on other sites More sharing options...
GunMetalR33 Posted March 2, 2006 Share Posted March 2, 2006 maybe a blocked cat? Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1990205 Share on other sites More sharing options...
Amadeo Posted March 2, 2006 Author Share Posted March 2, 2006 thanks for the input guys, i will go to my mechanic and have him analyse it, cheers. Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1991756 Share on other sites More sharing options...
Master Posted March 3, 2006 Share Posted March 3, 2006 Correct me if im wrong but if a clutch was slipping, u would not be goin from 5k DOWN to 4700rpm... It would be the other way round cause ur affectively reducing load on the engine.... Maybe some sort of engine management issue for a certain load condition and rev range. U'd have to play around with diff Throttle positions once u reach that condition n see if it makes a diff, id imagine these ECU's get their load readings off the TPS. Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1994417 Share on other sites More sharing options...
33GTT Posted March 3, 2006 Share Posted March 3, 2006 (edited) Sounds like maybe a loss of fuel pressure,,, Edited March 3, 2006 by 33GTT Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1994857 Share on other sites More sharing options...
J_Red33 Posted March 5, 2006 Share Posted March 5, 2006 I personally doubt that it's something electronic. How does a manual car suddenly drop 300 rpm without dropping speed at the same time? They're not like an automatic which will vary revs according to how much throttle is applied.... unless the clutch is slipping. If the revs are higher torque has less of a role to accelerate the car. I'd say chances are he's slipping at middle revs at peak torque. When power takes over the clutch bites again Link to comment https://www.sau.com.au/forums/topic/107477-revs-drop-at-5000-to-4700-at-3rd-gear-and-then-slowly-struggles-to-climb-what-could-be-the-problem/#findComment-1996726 Share on other sites More sharing options...
