Revs Drop At 5000 To 4700 At 3rd Gear And Then Slowly Struggles To Climb. What Could Be The Problem?
Hi guys,
Can someone tell me what the problem could be?
When I rip the 34gtt, 1st and 2nd are sweet but as i put it into 3rd and once it reaches 5000 the revs drop down to 4700 and then it lags and struggles to climb back up and once it passes 5000 its normal again...
I am losing power at this point and would like to know where the problem lies? can someone please help me?
Any advice would be greatly appreciated, thank you.
Clutch dude... Between that rev range you're pulling the most amount of torque therefore a good chance it may be slipping. It's a good indication that your clutch is on the way out.
Yeah have to agree clutch is a strong chance. Not really sure why it would then struggle to accelerate once it's bitten though, bit strange. Could be just that it drops just below the rev point that the cam is meant to switch between the low & high advance setting. ECU may be getting confused since ur on full throttle & the revs suddenly drop.
^^ nope not neccessarly..
it can start to slip from 3rd and onwards, or even in 2nd.. After a while, if you dont replace your clutch, it will start slipping from 1st, and u wont be able to get past 20ks.. ahhah from experience..
I remember drivin on the last day to the workshop, with the clutch slippin in 1st, i could not go faster than 20ks..
Might not even be your clutch.. maybe a more knowledgable person, could suggest something else..
Correct me if im wrong but if a clutch was slipping, u would not be goin from 5k DOWN to 4700rpm... It would be the other way round cause ur affectively reducing load on the engine.... Maybe some sort of engine management issue for a certain load condition and rev range. U'd have to play around with diff Throttle positions once u reach that condition n see if it makes a diff, id imagine these ECU's get their load readings off the TPS.
I personally doubt that it's something electronic. How does a manual car suddenly drop 300 rpm without dropping speed at the same time? They're not like an automatic which will vary revs according to how much throttle is applied.... unless the clutch is slipping. If the revs are higher torque has less of a role to accelerate the car. I'd say chances are he's slipping at middle revs at peak torque. When power takes over the clutch bites again
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
    • If it's a factory 20de manual probably has the 6 bolt flywheel in which case the det clutches won't work as they're 9 bolt.
    • All RB push clutches are interchangeable. AFAIK, the 4cyl ones are not. Different flywheels. The RB small box is not identical to the 4cyl boxes. Just very similar.
    • Hi. I need a new clutch for my gearbox. It is a factory smallbox behind RB20DE NEO. What options do i have? If iam not mistaken the gearbox should be the same as in R32 GTST and Nissan S14/S15? I found some Xtreme Clutch Stage 1 for S14/S14 (i dont know if you know the brand) (UK) OR...is the clutch same as in the bigbox from RB25DET?   Thank you!
    • Listening to an artist called "the flashbulb". Not bad. Makes some fairly well researched youtube vids in various things.
